Throw out/ thrust bearing noise
Scott370z
From what I have seen on here in the last 12 years thrust bearing noise in the 350s is quite normal and I experienced it on my first 350,
But if there are no other issues with the drivetrain/changing gear then just accept it as part of the car's character and wait until there is a need to change the clutch.
Always helps to meet up with other Zed owners and compare with theirs :thumbs:
Is this something that gets worse over time and can it cause damage longer term?
How much would it cost to put right?
May be worth getting an expert opinion so you can get it sorted by the 'dealer' while under warranty.
Plenty of experts on here of course but if I were you I would want someone to have a proper listen and confirm that it is indeed the thrust bearing and not something else. Maybe there is a mechanically minded Z owner near you who could help?
  • 8 months later...
