205 GTI - Time trials Help
MrLizard
Hi everyone, I am in the process of getting into sprints etc... done a few autotests before but nothing requiring the MSA national b license,
Anyway, planning on getting a 205, wanted something in the beginner class, and the stats arnt bad, engine below or equal to 1.6 and weight minimum is 800kg, gti is 804kg and obviously 1.6ltr.
Has anyone had experience in sprints and/or 205's, is there an alternative i should look at?
The reason for such a car is I can afford to loose the cash and take the 'hit' as it were, im sure a TT Rx-7 would be better (and not french) but i might not enjoy it so dont want to chuck loads of money at it 'yet'
Any advice would be welcome,
Thanks in Advance
Mr Lizard
106 rallye???? :teeth:
Probably best with either 205, 106 or saxo vtr/vts as the french handling is generally very good. The cars fall to bits but usually on the inside! If it's stripped out it won't!
Fiesta Mk2 XR2 or Nova GTE are both 1.6 and a bit more old skool.
Thats an interesting point, the rules stipulate that the car must have the original number of seats and the original dash in tact, you can strip the gumph behind the dash, clock, radio, some useless wiring for interior lights etc, including carpet headlining etc... but nothing else
However if i strip more than 4kg worth im stuffed because although i weigh a fair few kg's its the unladen weight of the car that counts. and needs to be more than 800kg's
Ill have a look at what you suggested though, 205 isnt 'that' tunable without serious work, though i thought nova's handled like a lampost ?
MrL
Was there a decent version of clio around 1.6?
the 16V was an 1800 wasn't it?
205 GTI is a very good choice. I would suggest charade GTTI. It's a 1.0 but VERY tuneable as it's turboed. Not sure on weight though or if you'd be left behind!
What about something old school RWD like a mk2 escort? A 4 door is reasonable money and would be Sooooooo much fun!
Saxo VTS is 16V and pretty tunable.
16v would be nice, the pug only being 8, saxo vts is an interesting thought actually, i might have a look on ebay, whatever i do get an tune ill leave a running commentary on here :) however well or badly it goes.
escort crossed my mind but RWD again takes me out of the lower class n puts me against supras etc so i might as well use the zed :p (which i cant afford to loose)
