Rear Mount Turbo (DIY)
Jake.Lowther
It's been awhile got some time to work on it again and some new goodies to play with. Will be posting more pictures of my progress over the next few days.
Got myself a heavy duty metal bandsaw and just over 6 metres worth of 304 stainless pipe, now comes the delightful job of routing all the pipework and welding it together.
I've made a start and will continue to work on it over the next couple of days.
Edited by Jake.Lowther
  • Like 5
Couple more bits done got to take some more pics tomorrow.
Firstly started bench testing the oil system for the turbo gotta play around with it but atm got it set to 45psi to the turbo. Also drilled and mounted the small oil resorvoir i made to the crash bar using 10 nuts and bolts just to be safe :lol:
Also first time making AN hoses by cutting them and adding the connectors to the end luckily I've had my tentus booster shot because I got pricked and stabbed roughly 200 times while trying to fit them (give or take a hundred)
20190204_143157.jpg.55747d53d9cb5fc7f037fbdda883f0f7.jpg20190204_164807.jpg.ceb33a15dd3229251f7416134630d849.jpg
Also started routing the pipe work from the intercooler around and over the lower arm. Complete pain in the ass as I'm sure any of you that have done a rear mount will know, working out the max travel distance of the wheel, ARB, lower arm, steering rack etc. But i think I'm home from tacked everything together will test it tomorrow and if we're all golden I can then continue the fun :cold: only another 4 odd metres to go...
And finally welded together the pipework for the exhaust side of the turbo, had to do a bit of make shift forging with a couple of butane blow torches heating and hammering the 3" pipe into a rectangle shape so it would fit the flange and still be round enough to weld other bits to. Came out alright if I don't say so myself B)
  • Like 3
Test fitted the pipe all seems good need to slightly adjust the rotation of the 3" exhaust flange since I tacked it blindely. But not bad for a first attempt
Test fitted the IC pipe everything seems to fit perfect so onwards with more piping :boxing: I'm going to mount the pipework to part of the subframe just above the lower arm since I'm using smaller 2.25" pipe I've got plenty of room.
** excuse my DIY blanking plates for headlight washer deletes :lol: **
  • 5 months later...
  On 11/08/2019 at 19:54, Ortega_9 said:
Did you get this done mate?
Expand
Still working on it, moved into a larger unit. Bought a load more machinery including pillar drills and metal lathes. I will do an update soon only just got my car moved over last weekend. The kit itself is basically done just needs the wiring and other bits sorting now.
  • 1 year later...
