Alexp1980 Posted November 4, 2018 Share Posted November 4, 2018 Hi guys, i know there are quite a few threads on this but none seem to cover my issue. Both my front and rear washers have suddenly stopped working at the exact same time? I have checked the fuses in the battery compartment and all seems fine. What are the chances you of both pumps packing up at exactly the same time?? Somehow I feel I’m missing something hear. Quote Link to comment Share on other sites More sharing options...
OnlyAfro Posted November 4, 2018 Share Posted November 4, 2018 Mine both died simultaneously. Thought it was weird too, especially when I have a rear washer delete so never use that one. You can always check by disconnecting the pump and feeding it some voltage directly. Quote Link to comment Share on other sites More sharing options...
Alexp1980 Posted November 4, 2018 Author Share Posted November 4, 2018 So annoying. Thought it must be the fuse being both of them. Will feed some power to them and see if that’s the problem when I can get under there to get to them. Quote Link to comment Share on other sites More sharing options...
G1en Posted November 4, 2018 Share Posted November 4, 2018 Yes, both mine packed in at the same time as well. There is a thread on that too. Must be common(ish) fairly straight forward to replace. Quote Link to comment Share on other sites More sharing options...
Alexp1980 Posted November 5, 2018 Author Share Posted November 5, 2018 Anyone have the link to the thread?? Quote Link to comment Share on other sites More sharing options...
G1en Posted November 5, 2018 Share Posted November 5, 2018 This is the thread i did, think it has links to other threads also. Quote Link to comment Share on other sites More sharing options...
blazemaguire Posted November 24, 2018 Share Posted November 24, 2018 The are there 2 washer pumps I believe, both on the washer fluid bottle (gotta go in through the offside front wheel arch) that supplies the rear and the front washers seperatley. they do fail, but are cheap on eBay. If both have gone at the same time might be a fuse? Quote Link to comment Share on other sites More sharing options...
scobie140 Posted November 24, 2018 Share Posted November 24, 2018 I got a new washer pump for £8ish from euro car parts when mines failed a while back. Quote Link to comment Share on other sites More sharing options...
veeg33 Posted November 24, 2018 Share Posted November 24, 2018 Both pumps are different, mainly just the connector. Make sure you buy one each. Quote Link to comment Share on other sites More sharing options...
