Will99Z Posted October 29, 2018 Share Posted October 29, 2018 Hi all, I have an 09 HR 350 with around 30k miles on the clock. It has been minimally modified, currently has Invidia Gemini Dual Exhaust with Berk HFC's and a Stillen Intake. I'd like peoples advice on what i should consider doing next, not looking to do anything extensive like super or turbo. But would like to improve my performance/ power somewhat. Thanks, Will Quote Link to comment Share on other sites More sharing options...
veeg33 Posted October 29, 2018 Share Posted October 29, 2018 Have you remap it with all the add-on you have added? I might be wrong but I think you have maxed out on stuff you can add to get more power. If you track you car, next upgrade would be brakes - Better disc, pads, braided lines, etc........after brakes would be the clutch and you are pretty much done. 1 Quote Link to comment Share on other sites More sharing options...
davey_83 Posted October 29, 2018 Share Posted October 29, 2018 Headers Cams Up rated valve springs *allowing for higher rpm Lightweight Pulleys Lightweight Flywheel High comp. pistons Stroker kit Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted October 29, 2018 Share Posted October 29, 2018 Coilovers and arb's, guarantee you car will be "perform" better than anything a remap will give you 1 Quote Link to comment Share on other sites More sharing options...
Sim Posted October 30, 2018 Share Posted October 30, 2018 On 29/10/2018 at 13:43, davey_83 said: Headers Cams Up rated valve springs *allowing for higher rpm Lightweight Pulleys Lightweight Flywheel High comp. pistons Stroker kit Going down the NA route will end up costing the same as a supercharger but for less gain. 23 hours ago, Jetpilot said: Coilovers and arb's, guarantee you car will be "perform" better than anything a remap will give you Handling mods are well worth doing. I hardly ever do engine work on bikes, just sort the handling and make them far easier to get more out of within my riding ability. Quote Link to comment Share on other sites More sharing options...
