Keyser Posted October 27, 2018 Share Posted October 27, 2018 (edited) Hi all, I need some help please, When I stripped the old 350z I took loads of measurements so I could build my Ford Pop using the rear suspension but I forgot one From the top of the rear spring hanger, it sticks out about a cm from the inner wing - This thing Yours will still be attached To the shock absorber mounting point here So from the top of the plate in pic 1 to the bottom of the shock - the red line in pic 2. can anyone put a tape measure against one and let me know how far it is please. Thanks Guys n Gals Keyser Edited October 27, 2018 by Keyser Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 1, 2018 Author Share Posted November 1, 2018 bump Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted November 1, 2018 Share Posted November 1, 2018 Hello mate, I can definitely do this on the weekend if you don't mind waiting a little bit ? I'm updating my suspension, so it'll be easy peasy. 2 Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 1, 2018 Author Share Posted November 1, 2018 2 minutes ago, RobPhoboS said: Hello mate, I can definitely do this on the weekend if you don't mind waiting a little bit ? I'm updating my suspension, so it'll be easy peasy. That would be awesome if you could please I think I can wait until the weekend I doubt I'll be even close to needing by then - I just forgot to take that one measurement Thanks 1 Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted November 3, 2018 Share Posted November 3, 2018 I'm just under the car now... So the spring plate is over the spring of course but I'm slightly confused as to what you want measured exactly. It's over the spring bucket not the shock. I'm probably reading it wrong! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 3, 2018 Share Posted November 3, 2018 I'm with you Rob: Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 3, 2018 Author Share Posted November 3, 2018 Just got back in - A picture should help Distance between the 2 red lines so top of spring carrier to shock mount Thanks 1 Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted November 5, 2018 Share Posted November 5, 2018 Ahhhh ok. I'll be under it again later in the week, so no problem ! Quote Link to comment Share on other sites More sharing options...
