Zed Shed Antics - Something will happen!
Keyser
Good evening my trusty 12 readers :thumbs:
I hope you are all well on this cold and damp evening.
So a catch up on the week to get us going..........................
Finished the other shelf
Then got the BIG tab;le out
Spent 2 hours cutting the middle legs off - the reason may become apparent later in the build, then got it level.
I bought 2 yes 2 digital levels :thumbs:
I then made these
to attach the cross member
it's level the other way as well :thumbs:
Had to sort the heat warped chassis rail
This one-
relief cut and clamped
Welded
cleaned it up and it's much better now :)
I fitted the rails and checked everything was true
Happy with that, I had this all ready for Saturday morning :)
More later .....................................
  • Like 3
Yes it's later @andybp  :lol:  If you're that bored you could reply to my pm ;)
Nice @andy james :thumbs:
So this is the next on the list -
I got this rotary table with my milling machine and have used it twice, the problem is that it is hard to use and the shaft is bent so it keeps sticking and it takes about an hour to do a full rotation using the handle :lol:
Anyway I put the shaft in the lathe to bring it back to true,
put a new thread on the end
Found this - I think it's a brake piston from a metro :shrug: anyway it made a good pulley :)
Made another pulley from some bar stock
Then added a windscreen wiper motor
It's fab isn't it?
I thought I'd test it before adding a speed controller - works well, here's a little vid
:lol:  I Love it :lol:
Random picture of a foot for @mattross1313
More in a mo :thumbs:
Edited by Keyser
  • Like 3
Here's a shocker for you - work on the Pop :scare:
Started by bolting the jig I made from @Beb 's car to the chassis rails
Cut some metal up
made my first 2 upper control arm mounts
Then made a top plate
Those that read the Rotary table post above will have noticed the original top mount being cut up like so
Then the new top mount
With a bit of welding and sanding the two became one
The plate was then trimmed to a sensible size
I said to Mrs Keyser "It looks OEM" she said "only if OEM means Over Engineering Maniac" - Not sure how to feel about that :shrug::lol:
anyway between that and the rotary table build that's all I had time for today :( Left it here
More tomorrow (as soon as I sneak out of the shopping trip to Ikea :scare::ninja::lol:
Keyser
Maximum Effort :thumbs:
  • Like 4
