Nugget Posted October 7, 2018 Share Posted October 7, 2018 Hi looking for a quick fix or some advise? My engine management light came on, on the way home from Trax, I stopped and carried out the pedal dance and it went out, but I noticed when I pressed the accelerator pedal down and then off the EML was flickering, when I got home I turned of the engine and started her up again and the light stays on until you do the foot dance again? Any ideas! Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted October 7, 2018 Share Posted October 7, 2018 Any codes stored and given with the pedal dance? If so post up and someoneay know. Quote Link to comment Share on other sites More sharing options...
Nugget Posted October 7, 2018 Author Share Posted October 7, 2018 How do you get the code, is it the number of flashes the EML does when reset? Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted October 7, 2018 Share Posted October 7, 2018 (edited) It will flash the code stored as above Edited October 7, 2018 by HEADPHONES Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted October 9, 2018 Share Posted October 9, 2018 (edited) I just got one of these, https://www.ebay.co.uk/itm/NEW-U480-Car-Engine-Auto-Fault-Code-Reader-OBD-2-Scan-Tool-Diagnostic-Scanner-UK/302214319524?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 works a treat, better to know the code rather than keep resetting it. Edited October 9, 2018 by Willsy1980 Quote Link to comment Share on other sites More sharing options...
Nugget Posted October 10, 2018 Author Share Posted October 10, 2018 Where do you plug it in, saves me looking it up? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 10, 2018 Share Posted October 10, 2018 The OBD2 port is under the dash on driver's side. Quote Link to comment Share on other sites More sharing options...
Nugget Posted October 13, 2018 Author Share Posted October 13, 2018 Ok say the cheap OBD 2 scanner worked but found no fault codes? Got my son to repeat the pedal dance and two codes came out, 1166 & 1157 and then the reset worked. Light is now off, but if anyone has any info on the codes it would be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 13, 2018 Share Posted October 13, 2018 These are Air Fuel Ratio and Heated Oxygen sensor codes. Will only require attention if the EML comes on again. Quote Link to comment Share on other sites More sharing options...
