Justthejedi Posted October 4, 2018 Share Posted October 4, 2018 Over a period of a week my local tyre/exhaust place have attempted to remove my old sensor but cannot get it off!.....tried heat, penetrating fluid etc. They can unscrew it x3 times and then the thing tightens up!....feels like the thread will strip and then I'll be in a world of pain and they aren't a specialist for zeds. I'm not sure what to do. It throws a light up every couple of months so it's not an urgent problem. It's the pre-cat sensor. Has anybody else had this problem?......if so, how did you remedy it?.....or what are my options? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 4, 2018 Share Posted October 4, 2018 Best just to remove the manifold and tackle the sensor issue on the bench. Or you can force it insitu and hope that the thread in the manifold says intact. Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted October 4, 2018 Author Share Posted October 4, 2018 It’s due a service anyway with Westway so i’ll Ask them to check the exhaust for leaks just in case. If that is ok then I’ll get them to do it. Quote Link to comment Share on other sites More sharing options...
Umster Posted October 5, 2018 Share Posted October 5, 2018 What's the error code? That's probably the best place to start. Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted October 5, 2018 Author Share Posted October 5, 2018 P0200 Bank 1 sensor 1, so it's the drivers side pre-cat. Can you live with a faulty sensor?......the car runs absolutely fine. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 5, 2018 Share Posted October 5, 2018 DTC P0200 relates to injector system malfunction. Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted October 5, 2018 Author Share Posted October 5, 2018 Sorry, typo.....it’s P2AOO bank 1sensor 1 circuit range/performance Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted October 5, 2018 Author Share Posted October 5, 2018 Doing a bit of research, it might be an air leak and not the sensor, it’s just finding it. I’ll spray some water over the manifold, see if there are any bubbles. Quote Link to comment Share on other sites More sharing options...
Umster Posted October 5, 2018 Share Posted October 5, 2018 I had a 02 sensor code which ended up being a similar problem. Exhaust leak due to a few dodgy gaskets and a HFC flange which needed sanding down. Cobra products aren't always built to last so if you have Cobra HFC or Catback that would be my first point of investigation. Quote Link to comment Share on other sites More sharing options...
