SiriusProjects Posted September 29, 2018 Share Posted September 29, 2018 Hi All, Today I noticed that the recaro cover on my drivers seat had come away on the side. The edge of the cover has a rubber seal on it and this has come away from where ever it was held in. Has anyone else had that happen and if so, is it an easy thing to fix? If not, where can I get a new seat from? Thanks. The image attached is one I found on the net. Just wanted to illustrate the area where the cover has come away. Quote Link to comment Share on other sites More sharing options...
nissanjuke Posted September 29, 2018 Share Posted September 29, 2018 are these not under warranty, check it out first Quote Link to comment Share on other sites More sharing options...
SiriusProjects Posted September 29, 2018 Author Share Posted September 29, 2018 15 minutes ago, nissanjuke said: are these not under warranty, check it out first Just checked the warranty details and the warranty start date was the 28th April 2015 and lasts for 3 years. So unfortunately it's 5 months too late to make a warranty claim. I had thought about maybe taking it to car seat upholstery specialist, but was thinking it might be quicker and easier just to buy a whole new seat. Any help or advise would be appreciated. Quote Link to comment Share on other sites More sharing options...
Nso93 Posted September 29, 2018 Share Posted September 29, 2018 There’s a thread on the seat wear on the mk2 nismo. https://www.350z-uk.com/topic/119895-poor-quality-leather-on-nismo-recaro-seats/ Quote Link to comment Share on other sites More sharing options...
SiriusProjects Posted September 29, 2018 Author Share Posted September 29, 2018 5 minutes ago, Nso93 said: There’s a thread on the seat wear on the mk2 nismo. https://www.350z-uk.com/topic/119895-poor-quality-leather-on-nismo-recaro-seats/ Thanks for the link, but that's more to do with the quality of the leather. Whilst my driver seat is showing a bit of wear, the main issue I have is that the seat cover has actually come away on the side. It's no longer covered by the warranty, so unless it can be repaired, I think I'm going to have to get a whole new seat. Any idea how much a new one would be? Quote Link to comment Share on other sites More sharing options...
Nso93 Posted September 29, 2018 Share Posted September 29, 2018 46 minutes ago, SiriusProjects said: Thanks for the link, but that's more to do with the quality of the leather. Whilst my driver seat is showing a bit of wear, the main issue I have is that the seat cover has actually come away on the side. It's no longer covered by the warranty, so unless it can be repaired, I think I'm going to have to get a whole new seat. Any idea how much a new one would be? Think second hand the recaros in juke nismo go for around £4K for set. But you can get the recaro cs seats from around £1k online new. But that’s without the nismo branding Quote Link to comment Share on other sites More sharing options...
nissanjuke Posted September 29, 2018 Share Posted September 29, 2018 a new seat would cost about £1000.00, you could get a partial retrim for that for both seats on the same section, full leather retrim on both my seats on my 350z cost £750, so i would take it to get retrimmed and maybe change the colour of the leather red or white!!!!! Quote Link to comment Share on other sites More sharing options...
SiriusProjects Posted September 29, 2018 Author Share Posted September 29, 2018 6 minutes ago, nissanjuke said: a new seat would cost about £1000.00, you could get a partial retrim for that for both seats on the same section, full leather retrim on both my seats on my 350z cost £750, so i would take it to get retrimmed and maybe change the colour of the leather red or white!!!!! Thanks for the advice. I would definitely consider doing that. Quote Link to comment Share on other sites More sharing options...
antnee Posted October 1, 2018 Share Posted October 1, 2018 Has the material come away from the rubber edging? If not, you can just put it back in by hand. the material folds over on the rubber then pushes into a slot of the hard plastic of the seat. Should take about 2 mins to sort. Quote Link to comment Share on other sites More sharing options...
SiriusProjects Posted October 1, 2018 Author Share Posted October 1, 2018 1 hour ago, antnee said: Has the material come away from the rubber edging? If not, you can just put it back in by hand. the material folds over on the rubber then pushes into a slot of the hard plastic of the seat. Should take about 2 mins to sort. Thanks, I will give that a try. Quote Link to comment Share on other sites More sharing options...
SiriusProjects Posted October 1, 2018 Author Share Posted October 1, 2018 I've tried to push the car seat cover back into the slot and it is okay for a while, but the problem is that when I get in an out of the car, I rub against the side of it and doing so pulls the cover back out. Just out of interest I phoned my local Nissan Dealer to get a price for just the back part of the car seat. It's a bloody good job I was sitting down because the guy I spoke to quoted £5300.00. That did include VAT, but there is no way I can justify that sort of money on a replacement back for the seat. I'd rather go out and buy some aftermarket seats. While writing this I have also phoned a specialist car seat upholsterer in my area and they said they could fix the seat for me for a small charge. So I am going to take my car over to them on Tuesday and see what they can do. Quote Link to comment Share on other sites More sharing options...
antnee Posted October 2, 2018 Share Posted October 2, 2018 You may need to use a flat blade (ideally plastic to avoid marking the material) to fully push the rubber into the slot. Work all the way along the seat too. I had the same Recaros in a Clio and the sides would pop out every now and then. Quote Link to comment Share on other sites More sharing options...
Silverthorn Posted October 2, 2018 Share Posted October 2, 2018 (edited) My girlfriend had a recaro seat out of her Clio 197 F1 repaired as it split in the exact same position as you mentioned. The guy matched the material perfectly, repaired the seat and returned it back within 24 hours! Spotless job and only cost £200... Far cheaper than a new seat! EDIT: just noticed you were talking about the edge with the rubber coming away from the seat rather than the stitching separating... If the rubber has just came away then it can be tucked back in by hand as people have already said Edited October 2, 2018 by Silverthorn Quote Link to comment Share on other sites More sharing options...
SiriusProjects Posted October 2, 2018 Author Share Posted October 2, 2018 I have tried to tucking the rubber back in, but it just keeps coming out again. I visited a local car seat upholsterer this morning and they are going to sort it out for me. Got to take my zed in next week. Quote Link to comment Share on other sites More sharing options...
antnee Posted October 2, 2018 Share Posted October 2, 2018 I also had the bolster wear through, I took the cover off myself and a local place charged me £70 to sew in a new panel. Quote Link to comment Share on other sites More sharing options...
SiriusProjects Posted October 6, 2018 Author Share Posted October 6, 2018 Just out of interest, is it possible to buy just the car seat cover? Quote Link to comment Share on other sites More sharing options...
Ekona Posted October 6, 2018 Share Posted October 6, 2018 Be cheaper to get it repaired. Quote Link to comment Share on other sites More sharing options...
GranTurismoEra Posted October 6, 2018 Share Posted October 6, 2018 mannn, this is why i used to hop in and spring out. But then the cushion underneath could also start sinking..... someone mentioned retrimming in white leather if it was a garage queen maybe....would look good when clean Quote Link to comment Share on other sites More sharing options...
SiriusProjects Posted October 6, 2018 Author Share Posted October 6, 2018 I don't want to get a new cover, mine is being repaired. Was just curious if it is possible to get one. Quote Link to comment Share on other sites More sharing options...
antnee Posted October 10, 2018 Share Posted October 10, 2018 You should be able to just get the cover - will be a lot of £££ through Nissan though. Quote Link to comment Share on other sites More sharing options...
