leebottrill Posted September 24, 2018 Share Posted September 24, 2018 (edited) I have noticed in the last month that my car is doing a few strange things. Firstly the Revs seem to have a little dip at the bottom of the rev range when I put my clutch in to stop the car, secondly the transmission doesn’t feel smooth when I’m engaging and disengaging the Excelerator (when cruising). I have attached my YouTube Video link so you can see what I mean about the revs. Thirdly my exhaust has just started blowing and I’m wondering if that would affect the revs? Edited September 24, 2018 by leebottrill Quote Link to comment Share on other sites More sharing options...
CLASSIX Posted September 26, 2018 Share Posted September 26, 2018 Change air filter, clean throttle body, that cured mine. Quote Link to comment Share on other sites More sharing options...
leebottrill Posted September 27, 2018 Author Share Posted September 27, 2018 On 26/09/2018 at 02:04, CLASSIX said: Change air filter, clean throttle body, that cured mine. Did you have the same issue as me? Quote Link to comment Share on other sites More sharing options...
CLASSIX Posted September 27, 2018 Share Posted September 27, 2018 31 minutes ago, leebottrill said: Did you have the same issue as me? Yeah mine was doing pretty much the same so I removed air feed pipe to throttle body cleaned the throttle and changed the air filter, had no issues since. Quote Link to comment Share on other sites More sharing options...
leebottrill Posted September 27, 2018 Author Share Posted September 27, 2018 Sweet. My air filters are probably due for a change. No idea how to do the throttle body clean but I’ll either watch a video or get my garage to do it. Thanks man. Quote Link to comment Share on other sites More sharing options...
CLASSIX Posted September 27, 2018 Share Posted September 27, 2018 2 hours ago, leebottrill said: Sweet. My air filters are probably due for a change. No idea how to do the throttle body clean but I’ll either watch a video or get my garage to do it. Thanks man. Throttle body is easy clean, just make sure NOT to touch the butterfly valve when cleaning, get some carb cleaner or use wd40 like i did, 5 minute job. Quote Link to comment Share on other sites More sharing options...
CLASSIX Posted September 27, 2018 Share Posted September 27, 2018 You might just want to check all your clips on the variouse pipes that are on the air system to make sure no air leaks are occuring as well. including the PCV one as well that leads to the upper plenum. Quote Link to comment Share on other sites More sharing options...
leebottrill Posted October 2, 2018 Author Share Posted October 2, 2018 (edited) Unfortunately I believe this problem is to do with the leaking oil gasket. I spoke to someone at Cougar store today and all the symptoms point towards that. I have HR at 71,000 miles which is around the time this problem occurs apparently. I’ve attached a photo of my warm oil pressure. WHAT DO YOU THINK? Edited October 2, 2018 by leebottrill Quote Link to comment Share on other sites More sharing options...
Keyser Posted October 2, 2018 Share Posted October 2, 2018 I think it's low, BUT did it used to be higher and is now low, also when was the last oil change? My 370 is low at idle but as soon as I rev it goes up nicely Quote Link to comment Share on other sites More sharing options...
leebottrill Posted October 2, 2018 Author Share Posted October 2, 2018 It’s lower than it used to be. It’s also slightly juddery in lower speeds. Im worried it’s going to blow up now! Quote Link to comment Share on other sites More sharing options...
leebottrill Posted December 7, 2018 Author Share Posted December 7, 2018 It was a gasket problem. Gaskets changed and oil pressure back to 30psi when hot. Quote Link to comment Share on other sites More sharing options...
