GRIFFO1994 Posted September 17, 2018 Share Posted September 17, 2018 (edited) Hi all recently had a bottom end knock on my rev up so decided to rebuild it. I’ve bought the following parts in belief that they are the same as a normal DE main and big end bearings timing kit head bolts gasket set ( I know the oil pump gasket won’t be the same) clutch kit the above parts I believe are the same, althought im struggling to find an answer on it the con rods and piston rings are interchangeable. They are different part numbers on paper, but will the piston rings from a DE fit a rev up ? And same with the con rods ? I’ve heard lots of different things so looking for a definitive answer if possible ? Thanks jack Edited September 17, 2018 by GRIFFO1994 Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted September 18, 2018 Share Posted September 18, 2018 1 Quote Link to comment Share on other sites More sharing options...
GRIFFO1994 Posted September 18, 2018 Author Share Posted September 18, 2018 Bump Quote Link to comment Share on other sites More sharing options...
