Help! Fuel light faulty
Cheshiregirl
Known issue, you need to get the float sensors out of each tank side and give the contacts a good clean and reassemble, it's a bit of a pain I did mine years ago and it's better but it's never as good as it should be.
There's a guide somewhere I tried to find it but failed :( takes a few hours but it's the same procedure as replacing them except you just clean them (obviously!)
