Handbrake light?
xStric9x
Mmm pads are fine and fluid is at max :dry:
Mabe the handbrake needs tightening as i do have to leave it in gear if its on a hill.
That wont be it mate, take the lid off the brake fluid and make sure the float is working ok, check the wires on the top, wiggle the handbrake and watch the light to check for a lose connection, other than that do your pads have wires coming from them (wear indicators) check these wires
sounds like a lose connection somewhere to me
No electronic pad wear indicator on the 350Z, only tabs on the pads which will screech on the disc.
this light should only illuminate for low brake fluid and the handbrake
NOT for low brake pads ! (as phil says and just checked the manual)
so it likely to be a sticky float or a poor connection/ sticky switch at the handbrake lever
