daz8235 Posted September 2, 2018 Share Posted September 2, 2018 Hi I have just picked up a 370z black edition in Quarts and was after a bit of advice please (only had it a couple of days). When starting the manual inform you to push the start button untill to changes to the ON position then clutch in, neutral and then push the button. All it does is turn everything off. I can get it started with the foot on clutch and on brake at the same time. Am I doing something wrong ? Many thanks, ohh a few little pics didn't notice until I got it home it had a carbon fiber front lip and black badges and stainless exhaust. Quote Link to comment Share on other sites More sharing options...
mattross1313 Posted September 2, 2018 Share Posted September 2, 2018 Welcome, nice looking car To start her up, put the clutch in and press the start buttons once. No need to press and hold the button, no need to press the brakes. Quote Link to comment Share on other sites More sharing options...
daz8235 Posted September 2, 2018 Author Share Posted September 2, 2018 Cheers, just tried it and it didn't work. Got in the car made sure it was in neutral, press the clutch fully, press the start button and it just turnsto ACC on the button, press it again it goes to on, clutch down press again and everything turns off. strange.. Quote Link to comment Share on other sites More sharing options...
daz8235 Posted September 2, 2018 Author Share Posted September 2, 2018 its a manual if that's any different. Quote Link to comment Share on other sites More sharing options...
mattross1313 Posted September 2, 2018 Share Posted September 2, 2018 Mine is also manual, this is odd. On mine just clutch in, tap the start button and it then lights up through acc to ign then the engine fires up. I occasionally see a message on the dash saying no key....but then try again and it's all fine (likely my battery is dying). You have the key with you in the car yes? It's also fussy and doesn't start until less the key is inside the cabin. Quote Link to comment Share on other sites More sharing options...
daz8235 Posted September 2, 2018 Author Share Posted September 2, 2018 Yeah, key in pocket, not light warning of battery. Works fine if I have foot on clutch and brake. I have downloaded the manual so will have a read thru, thanks for your help. Appreciated. Quote Link to comment Share on other sites More sharing options...
daz8235 Posted September 2, 2018 Author Share Posted September 2, 2018 Wonder if its this http://www.the370z.com/engine-drivetrain/111443-problem-starting-clutch-engaged.html Quote Link to comment Share on other sites More sharing options...
sipar69 Posted September 3, 2018 Share Posted September 3, 2018 Should definitely start up with the clutch depressed. You could also try the same thing with the brake. This is for the auto version but it also works with the manual. Quote Link to comment Share on other sites More sharing options...
daz8235 Posted September 3, 2018 Author Share Posted September 3, 2018 Yeah works with brake. I will take it back to the garage (it’s under warranty) cheers Quote Link to comment Share on other sites More sharing options...
nissanjuke Posted September 3, 2018 Share Posted September 3, 2018 advice take it back to the dealer right away. Quote Link to comment Share on other sites More sharing options...
GranTurismoEra Posted September 4, 2018 Share Posted September 4, 2018 2 presses of start button to on position then clutch in and hold start button Quote Link to comment Share on other sites More sharing options...
Humpy Posted September 4, 2018 Share Posted September 4, 2018 I got a 40th - clutch in and press start button once. Good luck, def not right. 1 Quote Link to comment Share on other sites More sharing options...
antnee Posted September 5, 2018 Share Posted September 5, 2018 I just put clutch in and hold the button till it starts (about 1 sec or so), sometimes I release the button too quickly and it just goes to ACC Quote Link to comment Share on other sites More sharing options...
Wayne370Z Posted September 5, 2018 Share Posted September 5, 2018 (edited) Same with mine as the others above. Jump in with key in pocket, depress clutch, press and release button, starts up. (except the once when the battery had gotten low and struggled to turn it over). No need to press button to turn it on first, or hold it in, or press brake pedal. Edited September 5, 2018 by Wayne370Z Quote Link to comment Share on other sites More sharing options...
daz8235 Posted September 5, 2018 Author Share Posted September 5, 2018 Cheers all been onto the garage. Quote Link to comment Share on other sites More sharing options...
