N4eay Posted August 28, 2018 Share Posted August 28, 2018 Wanted - 20mm Eibach spacers for 370z. Thanks Quote Link to comment Share on other sites More sharing options...
N13GEY Posted September 2, 2018 Share Posted September 2, 2018 I've a set of 30mm coming off of a 350Z, next weekend. Any interest? Quote Link to comment Share on other sites More sharing options...
Ebized Posted September 3, 2018 Share Posted September 3, 2018 On 28 August 2018 at 14:37, N4eay said: Wanted - 20mm Eibach spacers for 370z. Thanks Word of caution fitting 20mm spacers on 370s. You are likely to find that the length of the front hub studs will protrud through the spacers with the front wheels having not having enough recess to allow the wheel to bolted flat to the spacer. Not an issue with 25mm spacers. See this link, but do not use the slip spacers I show there as they distorted and led to wheel judder. Quote Link to comment Share on other sites More sharing options...
N4eay Posted September 10, 2018 Author Share Posted September 10, 2018 Thanks Colin, I thought I had learnt my lesson on this as I recently brought Eibach 15mm spacers for the 370z only to encounter the problem you mention above. I thought 20mm spacers would be OK as my brother has 370 wheels with 20mm spacers on his 350. Will see if I can whip one of his wheels and spacers off to do a test fit! Cheers Nick Quote Link to comment Share on other sites More sharing options...
