Dash indicators and car memory not working
Kryptek49
Hi, my 57 plate HR is having a few electrical issues.
Yesterday I pulled a fuse to check the fuse size from the compartment near the accelerator pedal.  I replaced the fuse after about 10 seconds.
Today when driving the car, I noticed that all the clocks/mpg settings had been reset to 0, and that the indicator dash lights were not functioning (actual indicators are working fine)
I assume this has something to do with the fuse I pulled, but I've replaced all the fuses along the bottom row and this hasn't helped!
I'm not sure exactly which fuse I pulled, but I'm fairly sure it was one of the 10's along the bottom row - all of which I have tried replacing.
From searching on the forum other people have had similar problems which always resulted in a bad fuse, however there symptoms also included the dome & trunk lights not working - except they are fully functioning on mine.
Is there something I'm missing here? Any advice would be really helpful.
Here's a photo of the fuse box if it helps:
Thanks
Edited by Kryptek49
Well that was simple - I put the fuse back in the wrong slot.
For anyone who happens to be as thick as me in future and finds this thread - the 10amp fuse between the two 15s on the bottom row is meant to be in the slot below the fuse puller.
