Geometry/tracking
Primey
Hi all,
I’ve lowered my 350z on coilovers, but I’m now struggling to get the rear toe dialled in.
I’ve seen some rear toe bolts for sale but it looks as though it will need more adjustment than they will provide. It also has driftworks rear camber and tension arms fitted.
Had anyone removed material from the sub frame back to where that factory toe adjusters sit?
Any help appreciated!
I had to buy adjustable toe bolts and had to grind out the hole they bolt through to make it longer so you can get the extra adjustment needed. You can use a dremel or similar as space is quite tight. I got the eibach adjustable camber arms and toe bolts as a kit. The templates and instructions were included.
