Odd Noise pulling away
hawker1986
Hi all,
Just after some advice, driving the Zed today as I got to the end of my journey ive noticed an odd noise when pulling away as the clutch engages - sounds like a scratchy/rattly noise. Only seems to happen in 1st/reverse gear. It happens as you finish engaging the clutch, so you can get the car rolling with the clutch partly engaged before it happens. Any ideas what the cause might be?
Cars on 69500 miles
Thoughts much appreciated.
Thanks
Ed
Well I’ve worked out what the problem is as it got worse when I tried to pull the car out the drive. The heatshield above the back box has corroded off its bolts and is rattling around.
I don’t know how to pull it out though and I’m 60 miles from home!
Edited by hawker1986
