stirkac Posted July 26, 2018 Share Posted July 26, 2018 Hey everyone, RevUp software being one of most popular mods to do on a Z, few people decided to reverse engineer Nissan ECUs for the benefit of community. I don't know if anyone heard about it yet, but there is a tool called Nisprog, which enables you to dump and flash your own maps for free. Kind of what Subaru or BMW guys of the early 2000s have, rarely anyone uses paid products to do remapping. The project is still in early days so you don't get as many options as commercial software for now, but anything is possible in the future. You can change most engine parameters or flash ROM from cruise control enabled car to get your switches working. Anyhow, if anyone is interested, please have a look here http://www.romraider.com/forum/viewtopic.php?f=45&t=14867, where I've compiled a small tutorial. 6 Quote Link to comment Share on other sites More sharing options...
vroom811 Posted August 4, 2018 Share Posted August 4, 2018 Looks interesting. I'll keep my eye on this and may even attempt it if I'm feeling brave! Thanks for sharing. Quote Link to comment Share on other sites More sharing options...
stirkac Posted August 6, 2018 Author Share Posted August 6, 2018 Hehe sure mate, I was also reluctant in the beginning but it really isn't that hard. If you can reserve yourself some dyno time I bet you can make same numbers as you would on RevUp software. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 7, 2018 Share Posted August 7, 2018 Managed to dump my rom today and had a quick look at the rom file in RomRaider, looks good, but not changing anything! Need more time to experiment with the software. Posted a question over on their forums as I have a slight issue however, but waiting for my post to be approved Quote Link to comment Share on other sites More sharing options...
OnlyAfro Posted August 7, 2018 Share Posted August 7, 2018 Has anyone developed a good throttle map? Should be pretty universal, making it a great, cheap mod any owner can do without the cost of a full remap. Really tempted to get a cable and have a play. Would someone mind sending me a copy of their ROM so I can fiddle? Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 8, 2018 Share Posted August 8, 2018 There are some throttle tables, so (if you understood what you were looking at) it should be pretty easy. I dont have my ROM on me ATM as im it work, but i could upload mine when im home and i remember. Its not a base map though as i have an UpRev tune on which i assume is listed/set on those tables too. 1 Quote Link to comment Share on other sites More sharing options...
OnlyAfro Posted August 8, 2018 Share Posted August 8, 2018 I understand MoTeC throttle tables, so it depends how different it is, but should hopefully all make sense. I'd assume the PID gains are locked away and shouldn't need to be messed with if Nissan have calibrated it properly. From reading the UpRev tuning guide, the throttle has a "master" non-linear calibration, and then changing the x-axis values in those tables just scales the throttle against that curve, presumably with different tables for each gear if my understanding of the standard 1st - 3rd reduction in sensitivity is correct. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 8, 2018 Share Posted August 8, 2018 Mine also has the throttle restrictions removed (part of the tune process), so i guess youd need a base ROM too so you can read the changes made between the two versions, but i dont have an unmodified copy. Quote Link to comment Share on other sites More sharing options...
OnlyAfro Posted August 8, 2018 Share Posted August 8, 2018 I believe the restrictions were a myth. It was later cleared up to just be a case of less aggressive throttle curves in 1st - 3rd, but with 100% accel still being 100% throttle. I think a friend has an OBD!! cable, so I'll see if I can borrow it and get a stock ROM to compare against. 1 Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 13, 2018 Share Posted August 13, 2018 (edited) @stirkac - In Nisprog, once you connect is says something about the command "DTC" and something else to be able to see live stats and view any trouble codes, but whenever i issue one of those commands its not recognised. Is this a missing component of the source youve compiled or am i just doing it wrong? Edited August 13, 2018 by cs2000 Quote Link to comment Share on other sites More sharing options...
stirkac Posted August 13, 2018 Author Share Posted August 13, 2018 Hmm I never used this feature - what I am guessing you are trying to interface with freediag (a subtool, with which nisprog shares some logic). What are you trying to accomplish? There may be better tools for OBD data display/logging... Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 13, 2018 Share Posted August 13, 2018 Just an all in one thing in my car I have a small windows laptop (netbook style) in my car all all times with the nissan service manual PDF's, the programming software for my 2 step launch control, Consult III software and now this Nisprog and romraider software. Just thought if i could use nisprog to do any fault clearing/OBD2 reading stuff it would be cool. I know theirs other software out there that can do that of course. Quote Link to comment Share on other sites More sharing options...
