Brake Fluid Low - Query?
tspar
Just doing my monthly checks and noticed the brake fluid is low. Do you think I should be able to top this up myself or is it something you would recommend I give to local Nissan or Indie to do for me?. Nothing has popped up as a warning however?
As had been said, that is your clutch fluid and desperately requires topping up before your hydraulics fail.
Then check for clutch fluid leaks, which I can only assume maybe your CSC which means gearbox removal if your cat is a 370. or 350HR.
