Do I have a bad camshaft sensor?
ATJBoyd
Recently bought my 350 and it has been driving me mad. The car used to start fine on cold starts and stall out on warm starts. Now on cold starts it revs up, dies, kicks back to life and idles. Still stalls everytime on a warm start. I’ve reset the ecu, the idle and the throttle body closed and open positions. Doing research I’ve found the problem could be a bad fuel pump, a bad coil pack, a bad cam sensor, a bad O2 sensor or a bad flywheel. The car throws no codes so I don’t even know where to begin to check. The starting issues didn’t bother me before but the car now dies when driving if I put the clutch in and let the revs drop to idle. My specific symptoms make me believe it’s a cam sensor but I really can’t be sure. Has anyone had this problem with no warning lights or codes coming on?
