Marky67 Posted July 12, 2018 Share Posted July 12, 2018 Alreet lads, just wondering if any of you have replaced the fans ( cooling & AC) with aftermarket ones. Advice appreciated. My fans have gone down one after the other, checked and got voltage at both motors so looking to replace and hopefully not break the bank. I think I've heard moshito mentioned???? thanks for your help..... Again marky Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 12, 2018 Share Posted July 12, 2018 If your car is a VQ35DE then this is what you need: http://www.clarkmotorsport.co.uk/parts/Fans-and-Shroud-Assembly/MMFS-350Z-03 Quote Link to comment Share on other sites More sharing options...
Jack94 Posted July 12, 2018 Share Posted July 12, 2018 If you fancy giving it a go then this link has a simple guide to split the motors apart and repair them- I did it the other week because both mine had packed up, they work like new again now Initially I thought about buying new oem replacements... Until I found out they're £190 each. Personally I didn't fancy going aftermarket because I've heard they're a lot noisier and I only use my Zed as a daily or the odd spirited drive so no need for any extra airflow. Quote Link to comment Share on other sites More sharing options...
Marky67 Posted July 12, 2018 Author Share Posted July 12, 2018 That the replacement for an 55 plate mate? Are they a direct replacement or you gotta do some remodelling? Quote Link to comment Share on other sites More sharing options...
Marky67 Posted July 12, 2018 Author Share Posted July 12, 2018 I'll check that, cheers jack94 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 12, 2018 Share Posted July 12, 2018 19 minutes ago, Marky67 said: That the replacement for an 55 plate mate? Are they a direct replacement or you gotta do some remodelling? Direct replacement and plug and play: VQ35DE 2003 - 2006 Quote Link to comment Share on other sites More sharing options...
Panoz33 Posted July 13, 2018 Share Posted July 13, 2018 9 hours ago, ZMANALEX said: Direct replacement and plug and play: VQ35DE 2003 - 2006 Hi. Just out of curiosity, how do they mount on the stock radiator? Do they fit inside the plastic oem structure? Thanks in advance Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 13, 2018 Share Posted July 13, 2018 The Mishimoto comes with a new aluminum fan shroud and fits exactly as OEM. https://www.mishimoto.co.uk/mishimoto-nissan-350z-aluminium-fan-shroud-03.html Quote Link to comment Share on other sites More sharing options...
Ridz Posted July 16, 2018 Share Posted July 16, 2018 URGENT, just for info, Mishimoto UK are offering a 15% discount, today only. 1 Quote Link to comment Share on other sites More sharing options...
