Initial_j Posted July 4, 2018 Share Posted July 4, 2018 Another question When unlocking my car with the fob, one press unlocks the drivers door but have to press it twice to also unlock the passenger door Is that’s normal? Seems a strange design if so! Quote Link to comment Share on other sites More sharing options...
cmck13 Posted July 4, 2018 Share Posted July 4, 2018 Correct on your own, the passengers is left locked so no one can open the door from outside. Quote Link to comment Share on other sites More sharing options...
Jack94 Posted July 4, 2018 Share Posted July 4, 2018 I'm sure somewhere in the owners manual there's a way to change it between 1 or 2 stage unlocking using the fob.. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted July 4, 2018 Share Posted July 4, 2018 35 minutes ago, Jack94 said: I'm sure somewhere in the owners manual there's a way to change it between 1 or 2 stage unlocking using the fob.. Only on later cars, I don’t recall when it changed though. Toggled simply by holding the button for several seconds, iirc. 1 Quote Link to comment Share on other sites More sharing options...
Initial_j Posted July 4, 2018 Author Share Posted July 4, 2018 Oooh. Might give that a go as mine is a later car. Quote Link to comment Share on other sites More sharing options...
MDMetal Posted July 4, 2018 Share Posted July 4, 2018 Works on any car surely? I have a 54 plate and I switched the functionality Quote Link to comment Share on other sites More sharing options...
mr v6 Posted July 5, 2018 Share Posted July 5, 2018 This also works for my 05, but I left it so the passenger door stays locked. Quote Link to comment Share on other sites More sharing options...
350TM Posted July 8, 2018 Share Posted July 8, 2018 On 05/07/2018 at 18:24, mr v6 said: This also works for my 05, but I left it so the passenger door stays locked. I also have a 05 . But no keyfob.. Got buttons on my keys... how did you change it? Quote Link to comment Share on other sites More sharing options...
veeg33 Posted July 9, 2018 Share Posted July 9, 2018 doesn't work on my 54 plate =( Quote Link to comment Share on other sites More sharing options...
Daisyduke Posted July 9, 2018 Share Posted July 9, 2018 My 05 doesn't seem to do it either. Quote Link to comment Share on other sites More sharing options...
mr v6 Posted July 10, 2018 Share Posted July 10, 2018 Hold both buttons down for a few seconds, then unlock the car with the remote key, if you've done it right both doors will unlock. If you want to revert back to only the drivers door unlocking, just repeat the procedure. 1 Quote Link to comment Share on other sites More sharing options...
Daisyduke Posted July 14, 2018 Share Posted July 14, 2018 Yep....that worked. Thank you Quote Link to comment Share on other sites More sharing options...
