Lex300 Posted June 25, 2018 Share Posted June 25, 2018 Hi guys can someone confirm if this is normal idle seems low and i can feel the engine shake through the car and i can sometimes here a pop out the exhaust . If i bring the rpm up slightly with the peddle its fine just under the 1000rpm. But as i let of drops down im not sure what the rpm scale is but is that below 500rpm on the picture. With the aircon on it brings it up between the 1000rpm mark and the one below. But didn't want to run ac as it uses more fuel correct? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 25, 2018 Share Posted June 25, 2018 Best to run with the air con on to stabilize the tick over. Quote Link to comment Share on other sites More sharing options...
Lex300 Posted June 25, 2018 Author Share Posted June 25, 2018 2 hours ago, ZMANALEX said: Best to run with the air con on to stabilize the tick over. Ok so im best to have ac on does this drastically drop the mpg or is it not to bad. My first 350z so just learning things . Thanks Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 26, 2018 Share Posted June 26, 2018 Definitely will not drop your mpg significantly for you to notice. Quote Link to comment Share on other sites More sharing options...
slipstream Posted July 15, 2018 Share Posted July 15, 2018 What is the correct RPM and is the DE the same as HR ? Quote Link to comment Share on other sites More sharing options...
