cb350 Posted June 25, 2018 Share Posted June 25, 2018 Hi all, I know there have been similar questions on this in the past, but I haven't quite found exactly what I'm looking for... Basically I'm getting an engine error code P0350 (and only that code) - first off I was getting it with no apparent issues with drivability. I changed the leads and spark plugs, everything seemed fine for a while and then the error started to return again. Now I'm getting a misfire pretty much constantly (it's there at idle and under load). I know that P0350 code is coil circuit, so I'm guessing it's a coil pack that's gone down? If I had the money, I'd change all the coil packs but I'm sadly not quite rich enough at the moment :( So... 1. What's the best way to figure out which cylinder has gone down? Is there an easy method or should I pull the plugs and look for a spark on each one individually? 2. Could anything else be wrong? I read that I should check the earth cable at the front of the engine... I've checked it and can confirm it's there :D - how should I test for continuity, as it seems to disappear into a bigger loom? 3. It's a JDM '03 model. The coil packs all seem to be around £100 each. Are there any cheaper alternatives that actually work? Sorry if this is really basic and I've missed a post covering it. Any help greatly appreciated. Chris. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 25, 2018 Share Posted June 25, 2018 New coil packs are in stock for your model at £39.50 each. See my signature below. Just drop me a message if I can help further. Alex. Quote Link to comment Share on other sites More sharing options...
