KyleR Posted June 23, 2018 Posted June 23, 2018 (edited) So I went to start the car today after it being sat for a few weeks and I never bothered to hook up the maintainence charger, so no surprise it’s stone dead. However, even after hooking it up to another car with its ignition running, it’s still dead. No lights or anything. I checked the 2 ignition fuses and they seem fine anyone any ideas? Edited June 23, 2018 by KyleR Quote
ZMANALEX Posted June 23, 2018 Posted June 23, 2018 Charge the battery. A jump will not work if your battery is stone dead. Quote
KyleR Posted June 23, 2018 Author Posted June 23, 2018 Had the battery charging for the past 6 hours, which I know isn’t enough to charge it, but I figured I’d have got a dash light. Instead of connecting the negative to the chassis, I connected it straight to the terminal and had power again, but would repeatedly click very quickly if I tried to turn it over. How come it wouldn’t work with a dead battery? I’d have though connecting a 14v source to the battery would be virtually the same as a fully charged battery. Quote
ZMANALEX Posted June 23, 2018 Posted June 23, 2018 When your battery is dead, the battery that you are trying to jump it with is not only trying to start the car, but also charging the flat battery. So leave it hooked up for 30 minutes and then try again. However, best to just be patient and charge the battery fully. Then check the fully charged battery to make sure that it is holding its charge. Quote
