Yaw sensor bypass switch
Initial_j
Looking to put a switch into the yaw sensor to fully disable traction control on a aftermarket switch
found a few guides but for older 350z so the wiring colours are different
looking at attached picture, does anyone know which wires to use
mine is a late 2006 model, facelift interior/lights etc
picture:
have you tried unplugging it to see if it actually disables the traction control ? if so the old ones had a 12 volt supply, use a volt meter to find the 12 volt supply cut the wire and put the switch in there well theoretically anyway
The white wire with the red stripe is ground (earth in the Queen's english).  Interrupting this lead will take the yaw rate sensor out of the loop.  I recommend using this wire instead of the 12v wire to avoid any possible electrical glitches.
  • 5 weeks later...
On ‎17‎/‎06‎/‎2018 at 09:26, Initial_j said:
Thanks guys
andy- unplugging it compeletly would work but would have the dash lights on permanently. Rather have it switchable
have you installed this successfully?
  • 2 years later...
