Stutopia Posted June 16, 2018 Share Posted June 16, 2018 There’s a wide selection of ingenious, resourceful people on the forum, not to mention a load of you who know how to break things. I got rid of some unwanted gates at Stutopia Towers, but now I’m stuck with these. They need to go. Any ideas better than just dremelling them off to a razor sharp stub? Quote Link to comment Share on other sites More sharing options...
LRF4N Posted June 16, 2018 Share Posted June 16, 2018 Just roll the bin down a bit, job done 3 Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 16, 2018 Share Posted June 16, 2018 Dremel down, fill the hole so you can’t see it. Job’s a carrot. 1 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted June 16, 2018 Author Share Posted June 16, 2018 Things I have handy to use: chainsaw pressure washer raspberry pi knackered fridge freezer. None of these are working 1 Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 16, 2018 Share Posted June 16, 2018 Amazon prime a dremel then, and pop to Travis etc to get some cement to fill it with. Or you could just use some resin tbh, they’re small enough. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 16, 2018 Share Posted June 16, 2018 Lock a couple of nuts on the stud and screw out to break the seal or just get the angle grinder out. 1 Quote Link to comment Share on other sites More sharing options...
marzman Posted June 16, 2018 Share Posted June 16, 2018 Angle grind flush, and then drill into it to create a recess before filling. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted June 16, 2018 Share Posted June 16, 2018 A small amount of DIY Semtex will probably do the trick 1 1 Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 16, 2018 Share Posted June 16, 2018 Nuke the entire site from orbit. It’s the only way to be sure. 1 1 1 Quote Link to comment Share on other sites More sharing options...
G1en Posted June 16, 2018 Share Posted June 16, 2018 On 16/06/2018 at 09:28, LRF4N said: Just roll the bin down a bit, job done Expand If he moves the wall 2 feet back, he doesn't have to move the bin 1 Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 16, 2018 Share Posted June 16, 2018 Get a bunch of Mexicans to build a new wall? 1 Quote Link to comment Share on other sites More sharing options...
Keyser Posted June 16, 2018 Share Posted June 16, 2018 (edited) Well as you don't have a Dremel or an angle grinder I thought what would I do without either of those and I would either go with Alex's idea or in my case I'd get the oxy acetylene torch out and cut/melt them right back into the hole and fill over it. O you don't have oxy acetylene either?? What sort of a garage do you have?? OK then beat the end over to ninety degrees it will either snap or bend, if it snaps it will do it in line with the wall hopefully if it bends then put a hollow bar or adjustable spanner over the bent end and beat it anti clockwise, it should unscrew (if its that sort of stud) Alex's method may do the same thing) if it doesn't unscrew it should snap at the point that it is locked into the wall when you turn it enough. It may just loosen in the hole but then a crowbar should lever it out. You can get exterior grade filler so you don't need cement to fill the hole EDIT - What Ekona just said while I was typing this Edited June 16, 2018 by Keyser 1 Quote Link to comment Share on other sites More sharing options...
andybp Posted June 16, 2018 Share Posted June 16, 2018 On 16/06/2018 at 15:24, Ekona said: Nuke the entire site from orbit. It’s the only way to be sure. Expand You've gotta love a Sci Fi geek 1 Quote Link to comment Share on other sites More sharing options...
Lexx Posted June 16, 2018 Share Posted June 16, 2018 2 options for me... Multi tool with a narrow fitted blade for sawing metal. Sharp cold chisel and a good lump hammer. Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted June 17, 2018 Share Posted June 17, 2018 You could try some mole grips to see if it will un-screw . . . . Dremel or an angle grinder are the best options Quote Link to comment Share on other sites More sharing options...
