Dudey52 Posted June 8, 2018 Share Posted June 8, 2018 Hi, I'm currently running a cobra on my 350z. Looking to go back to OEM, I've found a member on here with a backbox but just looking for a mid pipe. I found this https://www.ebay.co.uk/i/121152157321?clk_rvr_id=1557581283855&vectorid=229508&lgeo=1&item=121152157321&rmvSB=true Would that produce the same sound as the OEM Nissan one? Quote Link to comment Share on other sites More sharing options...
longsh07 Posted June 8, 2018 Share Posted June 8, 2018 No way to tell for sure but looks like the standard pipe so should be roughly similar at least. This is the underside of mine on stock vs Milltek. As you can see I had to fill the joint between centre/rear sections as it had (surprise surprise) rotted away. Quality looks somewhat questionable IMHO but it will do the job. Quote Link to comment Share on other sites More sharing options...
