G1en Posted May 27, 2018 Posted May 27, 2018 Not sure how to explain this but when i hit a largish bump in the road or a decent sized bump under braking (ie when the weight is more forward) the suspension feels/sounds like its bottoming out. I have eibach pro street coilovers, eibach anti roll bars, eibach adjustable arms and polybushed so there is very little movement. I have basically tried jumping on the suspension turretts whilst in the garage and cant get it to make any noise. (Just normal suspension movement which is only around 1” as its so stiff) i cant see anything catching or with potential to catch either so am scratching my head to whay it could be other than bottoming out but the coilovers are set to max height and the bumps that cause the noise are not “massive” as such. The car is fairly low (around 4-5”) ground clearence so was thinking if it maybe the undertray or a brace catching the road. I have a zspeed metal undertray which sits low but its not that type of feel/sound anyway sorry for waffling. Any ideas for things to check? Quote
Flashback Posted May 27, 2018 Posted May 27, 2018 Have you checked the Y pipe? Mine catches first in most instances. Quote
G1en Posted May 27, 2018 Author Posted May 27, 2018 So does mine, but this is further forward and more to do with the suspension in my opinion. Just wondered if there is anything suspension/arm/bushing related i may have never replaced that could cause a bang over med-large potholes. Quote
G1en Posted September 13, 2018 Author Posted September 13, 2018 Think i found out the culprit today. Took a few speed humps at normal speed and it made a real bang/scrape. Got underneath the car when back home to find my shiney new front brace had eaten some of the road and as a result it had worn chunks off the front most part. Guess i will have to take it very slow over humps from now on. I cant even raise the front coilovers any more. The debris you see on the floor is what i pulled out of the brace around front 2 bolt sections. Quote
SHEZZA Posted September 13, 2018 Posted September 13, 2018 Ah bugger was thinking of one of these braces in the future! How much is the zed lowered by Glen ? I know @buster had one on his old 350Z lowered on teins, don’t think he had any issues at that height. Quote
G1en Posted September 13, 2018 Author Posted September 13, 2018 Its lowered by around 30mm but then i have 235/40/18 tyres rather than oem so that will lower a little more. The pic above is with front wheels on mini ramps and its still low. 1 Quote
