Window quick fix
New to this site so not sure if this is the right place to post... but I’ve just imported a 350z which had an undiagnosed window fault... undaunted I imported it anyway and today’s job was to see if I could get them working. I had a sparky on hand to convert one reversing light into a fog light for the MOT... so I took off the armrest and discovered that the window switches had been disconnected.
So, with it connected back up, the passenger window worked fine, dipping correctly when opening and shutting ... but the driver side would return to the middle when the door was closed. I held the switch while the window went down until I heard two clicks and then held it up until the window was fully up and I heard two clicks again. End result, the windows now perform correctly.
  • Thanks 1
