VDC Lights on when turning
.:Bullen:.
Hi guys not sure if in right section but had my 350Z for a few years now and when you pull away after a few yards the traction control & vdc lights come on and the car Judders for a second as if the abs is kicking in.  After that it drives as normal but the lights stay on.
I had the steering wheel shaft off the rack when I was building the car & I wonder if the steering angle sensor needs re calibrating ? That or perhaps an abs sensor ?
Anu help appreciated
If it stays on you should be able to get a code for the problem, have a search on how to pull that code or go to a garage and get them to plug their diagnostics in.
What size tyres are you running?
Edited by Jetpilot
10 minutes ago, StevoD said:
This sniffs of bad axle tyre ratios
Running 235/40/18 & 265/35/18 so slightly lower.
The strange thing however is that if I start the car stationary & turn full lock one way then full lock the other the lights come on and it doesn’t judder when pulling away ...
