Colin747 Posted May 15, 2018 Share Posted May 15, 2018 I need to replace the passenger front top arm which I'm assuming is the upper control arm (U shaped part at the top of the suspension). Are these worth upgrading or should I just use an OEM replacement? The car really is only used for road and maybe the odd track day (like once or twice a year). Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 15, 2018 Share Posted May 15, 2018 Only if you require adjustable top arms. Quote Link to comment Share on other sites More sharing options...
MrLizard Posted May 16, 2018 Share Posted May 16, 2018 Hi Colin, the oem one is quite good to be honest, as Alex says unless you want to increase the -ve camber or have adjustable there is no point, did yours fail? Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted May 16, 2018 Share Posted May 16, 2018 Unless you're on coilovers or springs with serious drop and you want to get optimum camber figures, OEM ones are fine. Is this the one you need? https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/10861-350z-dorman-control-arm-and-ball-joint-assembly-suspension-front-right-upper-521-606.html Quote Link to comment Share on other sites More sharing options...
Paul K Posted May 16, 2018 Share Posted May 16, 2018 @Colin747 what are the symptoms that determined the change., clonking or knocking Quote Link to comment Share on other sites More sharing options...
Colin747 Posted May 16, 2018 Author Share Posted May 16, 2018 I hadn't noticed any symptoms myself but when it was in for a service I was told it would need replaced for MOT he said it needs a "passenger front top arm" the part he showed me matches the one in the Torqen link. What symptoms would it show if it needed replaced? Quote Link to comment Share on other sites More sharing options...
Paul K Posted May 17, 2018 Share Posted May 17, 2018 i was hoping you could tell us!! most are familiar with the usual clunks associated with banana arms, drop links etc...just wondered if this made a different noise or at particular times (low speed, when turning etc.....) Quote Link to comment Share on other sites More sharing options...
Colin747 Posted May 17, 2018 Author Share Posted May 17, 2018 ahh sorry, I'll ask the mechanic how he spotted it and update you all Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted May 17, 2018 Share Posted May 17, 2018 Colin, You'd probably be fine with just replacing the bushes on the arms:https://www.torqen.uk/nissan/350z/suspension-steering/bushes/775-350z-energy-suspension-upper-control-arm-bushing-kit-73121x-uca.html Quote Link to comment Share on other sites More sharing options...
Colin747 Posted May 17, 2018 Author Share Posted May 17, 2018 He just got back to me there "Excsssive movement in the 2 bushes and balljoint is what they need to check for", in my case it was also causing vibration under heavy and motorway speed braking. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted May 17, 2018 Share Posted May 17, 2018 If the ball joints are gone, you'd need full arms. In stock. Quote Link to comment Share on other sites More sharing options...
Paul K Posted May 17, 2018 Share Posted May 17, 2018 Thanks Colin Quote Link to comment Share on other sites More sharing options...
Colin747 Posted May 22, 2018 Author Share Posted May 22, 2018 @Adrian@TORQEN is there any quality difference between the Doorman and OEM arms? Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted May 22, 2018 Share Posted May 22, 2018 Dorman has been supplying OEM parts for many, many years, top quality parts, see more details about Dorman here: https://www.dormanproducts.com/Pages/corporate/history.aspx Quote Link to comment Share on other sites More sharing options...
Colin747 Posted May 22, 2018 Author Share Posted May 22, 2018 Can't help but notice that didn't really answer my question haha I can understand if you're not allowed to directly compare manufacturers you sell or something though Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted May 22, 2018 Share Posted May 22, 2018 2 minutes ago, Colin747 said: Can't help but notice that didn't really answer my question haha I can understand if you're not allowed to directly compare manufacturers you sell or something though I didn't mean to avoid your question, nor there is any law that forbids me to compare the products. Nissan doesn't really manufacture all their parts, they different suppliers, one of them being Dorman as far as I know. So they're the same parts. Moog ones look a bit different, Dorman look very OEM like. Other than that I don't know how else I can compare 1 Quote Link to comment Share on other sites More sharing options...
Colin747 Posted May 22, 2018 Author Share Posted May 22, 2018 haha fair enough, was just in case there was anything obvious like quality of material etc. I'll get one ordered now, thanks for your help! Quote Link to comment Share on other sites More sharing options...
Colin747 Posted May 22, 2018 Author Share Posted May 22, 2018 Just to double check, this is the passenger side, correct? https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/10862-350z-dorman-control-arm-and-ball-joint-assembly-suspension-front-right-upper-521-605.html Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted May 22, 2018 Share Posted May 22, 2018 LEFT = passenger side on UK RHD cars - https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/10862-350z-dorman-control-arm-and-ball-joint-assembly-front-upper-left-521-605.html just checked, we have it in stock. Quote Link to comment Share on other sites More sharing options...
zelda Posted January 2, 2020 Share Posted January 2, 2020 (edited) On 17/05/2018 at 09:46, Adrian@TORQEN said: Colin, You'd probably be fine with just replacing the bushes on the arms:https://www.torqen.uk/nissan/350z/suspension-steering/bushes/775-350z-energy-suspension-upper-control-arm-bushing-kit-73121x-uca.html Bit of a thread revival.. is it a PITA job to replace just the bushes? What about vs. replacing the whole arm? (E.g. driveway job) Edited January 2, 2020 by zelda Quote Link to comment Share on other sites More sharing options...
Silverthorn Posted January 3, 2020 Share Posted January 3, 2020 @zelda Burn the old bush out and press the new one in It's a pretty simply job assuming you have some basic tools at your disposal; more than doable at home on the drive. In the past I've used a threaded bar and a socket that's slightly bigger than the bush to pull the bushes in. Popping the new bushes in the freezer for a few hours before can sometimes help to shrink them a bit so they press in easier. Quote Link to comment Share on other sites More sharing options...
andybp Posted January 3, 2020 Share Posted January 3, 2020 15 hours ago, zelda said: Bit of a thread revival.. is it a PITA job to replace just the bushes? What about vs. replacing the whole arm? (E.g. driveway job) Where are you in essex ? Quote Link to comment Share on other sites More sharing options...
zelda Posted January 3, 2020 Share Posted January 3, 2020 Near Chemsford. Sounds similar process to the diff mount bushes. They were a nightmare to remove though, so hopefully these smaller bushes would be easier. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 3, 2020 Share Posted January 3, 2020 For ease of fitment, best just to bang on a good preowned top arm if you are working on drive way as the bushings will require pressed out and in. Quote Link to comment Share on other sites More sharing options...
