Crank Pulley Upgrade for Supercharger
wizard
Wanted to gets some thoughts from those who either have or are considering upgrading their crank pulley in order to extract more power from their superchargers.
Stock DE crank pulley: 5.75”
Fluidamper crank pulley: 6.125
ATI crank pulley: 6.61”
Simply put the larger the crank pulley and the smaller the supercharger pulley the faster you will spin the blower and hence the more power you will produce. Using calculations from Vortech’s impeller calculator, upgrading crank pulley you would still be within the blowers RPM limit.
Does anyone have any thoughts on this?
Plan to run my fluidamper, 3.12 pulley and 32/28 cog pulleys on my v3 sci vortech (non rev-up), it should only just over spin the blower if i remember right, but the time it does this for/ the chance i actually hit the increased rev limit (7000rpm probably) will be so small it shouldn't do any damage, if maintained well. 53,000 is the max speed of the V2 SCi (couldnt find the V3 data atm.) and the speed it would go to on my setup is around 56,000 i think.
Seen a few post from america saying it should be ok to over spin the blower slightly as belt slip and acutally hitting the rev limiter are factors to consider.
Edited by evilscorp
Expand
Have a play around with Vortech’s impeller calculator. You’ll find that it’s actually quite tricky to get close to the impeller limit: https://vortechsuperchargers.com/pages/impeller-speed-calculator
32/28, ATIdamper, 2.87” pulley, 7200Redline = 52,380rpm
928 state that it should be fine to overspin blower by a few thousand rpm.
Expand
Err you have the cogs the wrong way round in the calculator that would defo blow up the blower 68000 rpm lol
Expand
Sorry what do you mean, i’m confused. How many teeth does your supercharger cog pulley and jackshaft pulley have?
edit -
ah yes you’re quite right, just checked supercharger 28, jackshaft 32.
Edited by wizard
