Another clutch bleeding question
Imaparana
Hi all,
fitted my Z (de) with a new oem slave and stainless line along with motul 600 fluid over the weekend.
bleeding was a nightmare but got it so bubbles stopped going out, I now have what feels like a decent pedal.
my question is that after pumping the pedal to bleed it, upon lifting the pedal up for the first time after it was stuck to the floor but the pedal felt fine, is this normal?
Should it have returned straight away?
it has been fine the past few days since
cheers
1 hour ago, davey_83 said:
Once the line is bleed properly the pedal will return as normal. The pedal not coming up as described, may have been the last bit of process the master was in need off.........
cheers for the reply, not sure I understand, it returns fine now, was just the one time finishing off the bleeding that it didn't retrun
Probably the last little bit that was needed, not allowing the pedal to come up however now it's ok which is the main thing fella. They're a pain to do and can cause dramas during bleeding.
