drewbie Posted March 27, 2008 Share Posted March 27, 2008 Hi Guys I have a newish GT Roadster. Trouble is when I crank up stereo the subwoofer is making the rear plastic panel vibrate and distort the sound really badly. Ruining my cruising ! The back rear panels seam split into two main parts just above the subwoofer. They don't seem to fit too tightly on mine and I think this is were the problem lies. Will take it in under warranty if I have too but wondered whether there had been similar issues out there. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted March 27, 2008 Share Posted March 27, 2008 no issues with mine drew. Don't know if it's more of an issue with roadsters. Have you tried a cleverly placed piece of thick cardboard wedge Quote Link to comment Share on other sites More sharing options...
drewbie Posted March 27, 2008 Author Share Posted March 27, 2008 no issues with mine drew. Don't know if it's more of an issue with roadsters. Have you tried a cleverly placed piece of thick cardboard wedge A few pieces of cardboard did the trick, but don't exactly look the part on a brand new sports car. Maybe it'll have to do until I can get it in to Nissan. Quote Link to comment Share on other sites More sharing options...
martinmac Posted March 27, 2008 Share Posted March 27, 2008 No probs with my roadster sound system and it gets used Not a bose though. As Mike says we have to live with little DIY refinements and the cardboard wedge is your friend. Quote Link to comment Share on other sites More sharing options...
stuey Posted March 27, 2008 Share Posted March 27, 2008 i think nissan trim in general is a bit viberatey...clicky...creeky.. and noisey........ Quote Link to comment Share on other sites More sharing options...
Sarnie Posted March 27, 2008 Share Posted March 27, 2008 i think nissan trim in general is a bit viberatey...clicky...creeky.. and noisey........ Yep It costs an extra £10k for non creaky interior (TT's and boxsters etc ) Quote Link to comment Share on other sites More sharing options...
M13KYF Posted March 28, 2008 Share Posted March 28, 2008 use a black marker to make the cardboard black, less noticeable Quote Link to comment Share on other sites More sharing options...
H5 Posted March 28, 2008 Share Posted March 28, 2008 Buy yourself a speaker kit of Dynamat from Halfords or an ICE dealer. Take it to the dealer and ask them to take the sub out, stick a sheet of it in the enclosure, and use the other bit to cut up and stick on the back of the panel. Not vibrations and 10 times better sound. Or do it yourself. Almost all cars with 'subs' in them rattle. No car is built to take 40Hz bass frequency at high volume, not rattle and make money. Quote Link to comment Share on other sites More sharing options...
drewbie Posted March 28, 2008 Author Share Posted March 28, 2008 Buy yourself a speaker kit of Dynamat from Halfords or an ICE dealer. Take it to the dealer and ask them to take the sub out, stick a sheet of it in the enclosure, and use the other bit to cut up and stick on the back of the panel. Not vibrations and 10 times better sound. Or do it yourself. Almost all cars with 'subs' in them rattle. No car is built to take 40Hz bass frequency at high volume, not rattle and make money. Cheers, I'll give it a go. Good weekend project. Quote Link to comment Share on other sites More sharing options...
fatalus Posted June 2, 2008 Share Posted June 2, 2008 I didnt quite get that H5, where exactly do you put these small pieces of dynamat? Sounds a good and cheaper alternative to dressing the whole area behind the sub with dynamat.. Buy yourself a speaker kit of Dynamat from Halfords or an ICE dealer. Take it to the dealer and ask them to take the sub out, stick a sheet of it in the enclosure, and use the other bit to cut up and stick on the back of the panel. Not vibrations and 10 times better sound. Or do it yourself. Almost all cars with 'subs' in them rattle. No car is built to take 40Hz bass frequency at high volume, not rattle and make money. Quote Link to comment Share on other sites More sharing options...
H5 Posted June 3, 2008 Share Posted June 3, 2008 On the plastic trim panel itself. The stuff has dampening (sound) propoerties so will help stop the panel itself resonating at certain frequencies. I didnt quite get that H5, where exactly do you put these small pieces of dynamat? Sounds a good and cheaper alternative to dressing the whole area behind the sub with dynamat.. Buy yourself a speaker kit of Dynamat from Halfords or an ICE dealer. Take it to the dealer and ask them to take the sub out, stick a sheet of it in the enclosure, and use the other bit to cut up and stick on the back of the panel. Not vibrations and 10 times better sound. Or do it yourself. Almost all cars with 'subs' in them rattle. No car is built to take 40Hz bass frequency at high volume, not rattle and make money. Quote Link to comment Share on other sites More sharing options...
fatalus Posted June 3, 2008 Share Posted June 3, 2008 You mean in front of the subwoofer cone and just behind the grilles(blocking the sub out of sight) or on the area of the plastic panel around the grill? And is one piece of dynamat enough for this area or even the enclosure behind the sub? On the plastic trim panel itself. The stuff has dampening (sound) propoerties so will help stop the panel itself resonating at certain frequencies. I didnt quite get that H5, where exactly do you put these small pieces of dynamat? Sounds a good and cheaper alternative to dressing the whole area behind the sub with dynamat.. Buy yourself a speaker kit of Dynamat from Halfords or an ICE dealer. Take it to the dealer and ask them to take the sub out, stick a sheet of it in the enclosure, and use the other bit to cut up and stick on the back of the panel. Not vibrations and 10 times better sound. Or do it yourself. Almost all cars with 'subs' in them rattle. No car is built to take 40Hz bass frequency at high volume, not rattle and make money. Quote Link to comment Share on other sites More sharing options...
H5 Posted June 3, 2008 Share Posted June 3, 2008 I mean when you look at the big trim panel behind the driver seat with BOSE written on it, if you turn it over and put small pieces on the back of it, it will help stop it resonating Depends on the size of the piece! Personally, I don't think you can over do it, you can never have too much. Anything will improve it, more will add to it. You mean in front of the subwoofer cone and just behind the grilles(blocking the sub out of sight) or on the area of the plastic panel around the grill? And is one piece of dynamat enough for this area or even the enclosure behind the sub? On the plastic trim panel itself. The stuff has dampening (sound) propoerties so will help stop the panel itself resonating at certain frequencies. I didnt quite get that H5, where exactly do you put these small pieces of dynamat? Sounds a good and cheaper alternative to dressing the whole area behind the sub with dynamat.. Buy yourself a speaker kit of Dynamat from Halfords or an ICE dealer. Take it to the dealer and ask them to take the sub out, stick a sheet of it in the enclosure, and use the other bit to cut up and stick on the back of the panel. Not vibrations and 10 times better sound. Or do it yourself. Almost all cars with 'subs' in them rattle. No car is built to take 40Hz bass frequency at high volume, not rattle and make money. Quote Link to comment Share on other sites More sharing options...
drewbie Posted June 4, 2008 Author Share Posted June 4, 2008 Should have reported back sooner. I did try it. One square piece behind subwoofer - seemed a bit lost in there but I trusted advice. Also got another square and cut little bits off to stick in a few loose gaps where two rear speakers are just above. Sounds a million miles better. Base now thumps into my back and there are no rattles. TOP MAN. All for £20 ! Thought I was in for a whole new ICE kit. Quote Link to comment Share on other sites More sharing options...
Lexx Posted June 4, 2008 Share Posted June 4, 2008 This is my weekend project, as the rattling in my car is driving me bonkers, and I dont think I could cope all the way to Le Man with it like it is. Just gotta figure out how to take the panels off now... Quote Link to comment Share on other sites More sharing options...
H5 Posted June 5, 2008 Share Posted June 5, 2008 Should have reported back sooner. I did try it. One square piece behind subwoofer - seemed a bit lost in there but I trusted advice. Also got another square and cut little bits off to stick in a few loose gaps where two rear speakers are just above. Sounds a million miles better. Base now thumps into my back and there are no rattles. TOP MAN. All for £20 ! Thought I was in for a whole new ICE kit. Have faith! Now imagine how much better the front speakers would sound if you did the same to the doors.... Quote Link to comment Share on other sites More sharing options...
drewbie Posted June 5, 2008 Author Share Posted June 5, 2008 Should have reported back sooner. I did try it. One square piece behind subwoofer - seemed a bit lost in there but I trusted advice. Also got another square and cut little bits off to stick in a few loose gaps where two rear speakers are just above. Sounds a million miles better. Base now thumps into my back and there are no rattles. TOP MAN. All for £20 ! Thought I was in for a whole new ICE kit. Have faith! Now imagine how much better the front speakers would sound if you did the same to the doors.... Not very practical. Don't think I could get trim off and then put back. Taking a sub-speaker out by 4 screws was about my limit. Unless you know a very easy and foolproof way ? Quote Link to comment Share on other sites More sharing options...
H5 Posted June 5, 2008 Share Posted June 5, 2008 Should have reported back sooner. I did try it. One square piece behind subwoofer - seemed a bit lost in there but I trusted advice. Also got another square and cut little bits off to stick in a few loose gaps where two rear speakers are just above. Sounds a million miles better. Base now thumps into my back and there are no rattles. TOP MAN. All for £20 ! Thought I was in for a whole new ICE kit. Have faith! Now imagine how much better the front speakers would sound if you did the same to the doors.... Not very practical. Don't think I could get trim off and then put back. Taking a sub-speaker out by 4 screws was about my limit. Unless you know a very easy and foolproof way ? True, it is a bit more of a job, but you can just remove the speaker from the door and not the whole door card..... Or get to a meet and get someone who has done it to help. Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted June 5, 2008 Share Posted June 5, 2008 http://liljerk.morpheus.net/350Z/front_speakers/ Quote Link to comment Share on other sites More sharing options...
fatalus Posted June 11, 2008 Share Posted June 11, 2008 Do you think it is best to use the dynamat in the front door speakers as shown in the dynamat kit box, around the speaker, or to put a piece of it on the panel back behind the speaker? Quote Link to comment Share on other sites More sharing options...
H5 Posted June 12, 2008 Share Posted June 12, 2008 Both if possible, stopping the mounting point and the chamber resonating as much will really help the speaker work better. Quote Link to comment Share on other sites More sharing options...
