speedo stopped working advice
scotzman
Hi All.,.
  Speedo on dash and digital not working .. On getting it checked out it was suggested the console behind heaters is at fault..
  Anyone any suggestions on recommended fixes  for this..
  Thanks
  On 27/04/2018 at 12:40, Jetpilot said:
Possibly the box, do you know a local owner that would swap over to try? Its a 5 min job.
is it an import?
Expand
Garage suggests white box behind heater.. dont know another 350z owner to try a swap. Also would just a different box work or would i need additonal components. Yes an Import.
thanks..
Edited by scotzman
It should be pretty self evident if the wiring looks like its been spliced, you are looked for something like linked below if you click on the speedo converters:
http://www.svaspeedos.co.uk/product_info.html
It might also just have the dial replaced, but then the trip would still be reading in kmh for the distance?
http://www.lockwoodinternational.co.uk/350z-part-no-c030.html
Take photos if you are unsure.
