OBX Individual Throttle Bodies
andybp
7 minutes ago, Jake.Lowther said:
May be a stupid suggestion but what about small mini ducted fans with some ducting pipe bringing cold air from outside into the bay, could be discreetly installed wouldn't have to go right to the intake trumpets.
Would lower the temps a small amount, anything creating air flow in the bay will bring the air temps down. Like the old BMWs had belt powered cooling fans.
already done it, it's a bit of an aluminium ducting and fibreglass bodge right now using a motorbike cooling fan but it makes quite a difference I'll post up a pic tomorrow if I remember
Ah fair enough it stopped most of your heating issues then?
Just now, andybp said:
have considered it but it'll be a pig of a job with the engine in
Could be worth it in the long run, would have to do some research in  heat reduction from the wrap. Also you can get heat resistant/insulating paint which if you put in the side of the block where the exhaust ports are I imagine would make a massive difference to bay temps.
picture as promised please bear in mind this is a temporary bodge to try to see what works and it has made a big difference 5-10 Deg
  • Like 2
Not a bad start I'd try something coming from either side where the headlight braces are if you can cram it in lol
9 hours ago, Daisyduke said:
4 hours ago, Bakkums said:
Sasha Anis did this: Cold air intake itb
the problem with most of your suggestions is that there just isn't the clearance it's hard to show in photo's but it's really tight.
just look at the engine bay in sasha's 350 and how much standard stuff is missing  and I'm pretty sure his bonnet wasn't standard either
but feel free to keep the suggestions coming as I'll be back on it soon, as I have just sorted out the electronics issues I've been having with the airride
  • 7 months later...
I'm not sure where to start with this so here goes
Just as the weathers getting reasonable and I can carry on with this project someone on here (Reecodecides to sell a set of new Jenvey ITB's at not much more than I paid for my knock off OBX ones so just out of curiosity I had to have them :shrug:
At first glance they are identical but looking closer the Jenvey ones are far superior.
The castings are better and of better quality aluminium with no impurities unlike the OBX ones
The machining is more accurate, I haven't had to finish tapping holes or countersinking and everything lines up without me re-drilling holes
The throttle bodies themselves open and close more smoothly
The supplied fuel rails will also fit unlike the OBX ones
After the initial fitting issues of the OBX ones were sorted the only thing they still occasionally do wrong is not closing fully causing it to idle a couple of hundred rpm faster than it should; on a track car this wouldn't get noticed on a road car it's a little irritating but not a big deal it's also doing it less with use
So without a doubt the Jenvey ones are better but are they worth £1400 more than I paid for the OBX ones an extra £600-700 on a road car I'd say yes but not £1400
but that's just my opinion
But now I do have a set of Jenvey ones for near OBX money I'm already preparing to swap them over
I've already drilled and tapped the manifolds for the vacuum system and also made some insulating spacers to go between the manifolds and the throttle bodies to help overcome some of the temperature issues with the current setup
  • Like 2
  • Haha 1
I’m sorry if I missed it but what are you using for a cable stay for the throttle cable.
Keep up the great work!
These are the insulating spacers I made to try to help with the heat issues
IMG_20190416_194107.jpg.29128d85f19cb2f9af6322af4763544f.jpgIMG_20190416_194056.jpg.351dd5dd3cc7077af9c8b81f36301901.jpg
also treated it to new manifold to head gaskets
unlike the OBX setup there was no additional work to be done before installation it seems Jenvey know how to drill and tap holes all the way through and countersink as required to the right depth ( OBX take note)
here is the manifold installed with vacuum pipework and fittings
and this is how it stands now
I have had it running but I need to balance the Throttle Bodies and sort out the accelerator cable
there were two things I had to do which I wasn't expecting one was shave a bit more off my filler cap nothing major
the other I wasn't expecting, the fuel rails didn't fit :scare: as per the OBX supplied rails the fuel injectors would have to be 15-20 mm longer was there a VQ fitted with much longer injectors ? I have 3 sets original UK , JAP import and GTR all the same length look at the picture not even close
had to cut the mounting brackets to make them fit all ok now
and before I go here's a couple of pictures that showcases the difference between the Jenvey and OBX ones
  • Like 2
Apologies for such vagueness,
Im not fully familiar with 350z yet - just bought one as a track toy.
But I bet your fuel rail issues are because they developed the kits on older 60mm Bosch style injectors whereas the ones in your photo's look like the newer, shorter 48mm long ones - perhaps your car is a facelift and thats something thats been overlooked.
Apologies again if Im teaching you to suck eggs or barking up the wrong tree, Im new to zeds but not Jap engines lol
J.
