steve3000 Posted March 26, 2008 Share Posted March 26, 2008 Evening all, Just had a poke around the car today and wondered where the amp is for the BOSE system? Is it really obvious or very well hidden Anyone point me in the right direction here? Cheers! Steve Quote Link to comment Share on other sites More sharing options...
stuey Posted March 26, 2008 Share Posted March 26, 2008 by the cubby holes behind the seat................i think Quote Link to comment Share on other sites More sharing options...
steve3000 Posted March 26, 2008 Author Share Posted March 26, 2008 Ah ok, in one of them??? Can't actually remember seeing anything there...but there are a few of those cubbys so maybe I didn't look in all! ...or do you mean it's hidden behind the trim somewhere? Will investigate more tomorrow Cheers, Steve Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted March 27, 2008 Share Posted March 27, 2008 by the cubby holes behind the seat................i think I thought it was in the boot, left hand side under the foam packaging under the carpet.................... Quote Link to comment Share on other sites More sharing options...
Ian Posted March 27, 2008 Share Posted March 27, 2008 by the cubby holes behind the seat................i think I thought it was in the boot, left hand side under the foam packaging under the carpet.................... yup, thats where it is Quote Link to comment Share on other sites More sharing options...
H5 Posted March 27, 2008 Share Posted March 27, 2008 by the cubby holes behind the seat................i think I thought it was in the boot, left hand side under the foam packaging under the carpet.................... yup, thats where it is It certainly is, and not as big as you'd think! Quote Link to comment Share on other sites More sharing options...
Chris`I Posted March 27, 2008 Share Posted March 27, 2008 by the cubby holes behind the seat................i think I thought it was in the boot, left hand side under the foam packaging under the carpet.................... yup, thats where it is It certainly is, and not as big as you'd think! Yup its tiny and on stilts haha Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted March 27, 2008 Share Posted March 27, 2008 There are actually two so you are both right The main speaker one is under the foam bit in the left hand side of the boot and there is once in the metal section behind the drivers seat which powers the sub. Quote Link to comment Share on other sites More sharing options...
steve3000 Posted March 28, 2008 Author Share Posted March 28, 2008 Thanks guys, I'm missing all sound on the left, so wanted to track down the cabling and amp! Had a peak in the boot and can see the edge of the amp behind the foam on the left. Couldn't easily remove that foam cover though (in the 5 minutes I tried!), seems to be stuck in behind every piece of plastic trim going? I guess I have to remove the back centre plastic piece with the light in it - any hints on removing this without breaking it? Cheers, Steve Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted March 28, 2008 Share Posted March 28, 2008 The only way I was able to get that bit out without breaking it was by removing the plastic trim panels. Quote Link to comment Share on other sites More sharing options...
Mathys Posted March 28, 2008 Share Posted March 28, 2008 Thanks guys, I'm missing all sound on the left, so wanted to track down the cabling and amp! Had a peak in the boot and can see the edge of the amp behind the foam on the left. Couldn't easily remove that foam cover though (in the 5 minutes I tried!), seems to be stuck in behind every piece of plastic trim going? I guess I have to remove the back centre plastic piece with the light in it - any hints on removing this without breaking it? Cheers, Steve I had the same problem and for me it was the Bose cd-player. Now it sometimes cuts all sound on the left, then on the right and then on both Or it mutes it almost completely. I honestly hate the POSE (piece of sh*t equipment) Quote Link to comment Share on other sites More sharing options...
H5 Posted March 30, 2008 Share Posted March 30, 2008 If you have the left channel going, it is a known fault and not something people have rectified with wire checks so far.... Let us know how you get on! Quote Link to comment Share on other sites More sharing options...
steve3000 Posted March 30, 2008 Author Share Posted March 30, 2008 Hi, cheers for the advice and info Does anyone know if this problem is usually down to the Amp or the headunit? I've done some searching on the forum and most say it's solved with a new h/u - I assume these still use the BOSE amp?...or is there an easy way to wire up an new h/u direct and disable the BOSE amp? Cheers, Steve Quote Link to comment Share on other sites More sharing options...
H5 Posted March 30, 2008 Share Posted March 30, 2008 Hi, cheers for the advice and info Does anyone know if this problem is usually down to the Amp or the headunit? I've done some searching on the forum and most say it's solved with a new h/u - I assume these still use the BOSE amp?...or is there an easy way to wire up an new h/u direct and disable the BOSE amp? Cheers, Steve AFAIK, it is a headunit issue. Replacement headunits will use the existing BOSE amp, yes. The problem you have with the BOSE set-up, is the output from the headunit (and therefore amp input) is at a different level to aftermarket headunits. Speaker level (high level) or phono / RCA level (low level) outputs are what aftermarket headunits use. The BOSE amp won't work with these. If you change the headunit, you will need a PAC ROEM adaptor to still be able to use the BOSE amp. Zedrush and others have done the same. Quote Link to comment Share on other sites More sharing options...
JAP350Z Posted March 31, 2008 Share Posted March 31, 2008 The amp in the boot isn't easy to reach. Have attached a pdf of what is involved. Quote Link to comment Share on other sites More sharing options...
