Oil in spark plug cylinder lead to misfire?
Smc1992
Hi guys
I know there are plenty of posts on this but I couldnt seem to find an answer, can oil in the spark plug cylinders cause a misfire?
My 350 is misfiring all the time and I have a p0300 code. The car is running horrendously so I took the coil packs out individually as the car was running to try and determine which cylinder the misfire is coming from and I have also removed my spark plugs to inspect and noticed they have seen better days. So my first port of call is to replace these and go from there.
From researching I see that I am in need of a new cam cover or a cam cover repair kit but id like to resolve the misfiring before tackling that job but if this could cause the misfire I might aswell resolve the cam cover to rule it out.
Sorry for the long post on a topic that is fairly well covered (just cant find the answer!)
Scott
8 minutes ago, MattRwebB said:
Glad you just put this up I’ve just changed my plugs and my back right hand (standing in front of the car) was covered in oil .. rest are dry .. will keep and eye on on this post :)
Same on my 06, no misfire though... Was led to believe its the rocker cover gasket
Standing in front of the car I have oil in the back right and back left, the rest are dry. Is your car running fine?
Yeah cam cover and rocker cover are the same thing I believe. I have seen repair kits are available to fix this. Maybe youve answered my question there, if yours isnt misfiring then mine must be for a different reason!
Replaced spark plugs and the car is running a lot better but still missing slightly. My OBD reader is now coming up with a P0300 but saying its a pending fault whereas before it was coming up as a current fault, not too sure what that means.
Thanks Adrian, once I have pin pointed the root cause of my misfire ill be investing in the repair kit!
