Matt V6Z Posted March 17, 2018 Share Posted March 17, 2018 Hi I brought my 350 in January and I am now looking into getting it mapped however I am unsure of the best place to go to. I live in Lichfield which is not far from Derby/Birmingham and will to travel so what advice have you got for me regarding mapping and where to go? see spec below 2006 Rev up GT JWT Pop charger Berks Hi Flow Cats Stillen Y-Pipe Fujitsubo legalis R Exhaust SuperPro Comp Bushes SuperPro ARB Bushes Power grid front and rear drop links HSD Dual Tech coilovers Tein rods/Ends Eibach toe bolts ebach rear camber arms 25mm wheel spacers EBC Black Groved Disks with Green stuff pads Quote Link to comment Share on other sites More sharing options...
G1en Posted March 17, 2018 Share Posted March 17, 2018 Horsham and Abbey are the two most zed owners use. Plenty of experience and both highly recommended. Both traders on here also. I used Horsham as they did a group buy deal last year Quote Link to comment Share on other sites More sharing options...
Matt V6Z Posted March 17, 2018 Author Share Posted March 17, 2018 Ok thank you. Do you know of anyone that’s been to tdi north? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 17, 2018 Share Posted March 17, 2018 A bit South of you but these guys will sort you out: http://www.litchfieldmotors.com/ Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted March 17, 2018 Share Posted March 17, 2018 Don't think Litchfield use uprev only ecutek which is only available on 370 Give them a call but I'm sure that's was the case last I heard Shame as They are great guys Quote Link to comment Share on other sites More sharing options...
350Butcher Posted March 18, 2018 Share Posted March 18, 2018 Litchfield do only do Ecutek (so 370z's only) Bit of a drive (but a nicer one, make sure you take the B4494 from Chieveley to Wantage on your way home its epic!!) but go and see Jez at Horsham he'll get the best from it for you. Looking at the pic of your car it looks like its running a load of positive camber on the rear (Unless the camera is distorting it) so get yourself a full alignment done while you're there! Also where did you get the Tein rods and ends? Thought they'd been discontinued a while ago! Quote Link to comment Share on other sites More sharing options...
Matt V6Z Posted March 18, 2018 Author Share Posted March 18, 2018 10 minutes ago, 350Butcher said: Litchfield do only do Ecutek (so 370z's only) Bit of a drive (but a nicer one, make sure you take the B4494 from Chieveley to Wantage on your way home its epic!!) but go and see Jez at Horsham he'll get the best from it for you. Looking at the pic of your car it looks like its running a load of positive camber on the rear (Unless the camera is distorting it) so get yourself a full alignment done while you're there! Also where did you get the Tein rods and ends? Thought they'd been discontinued a while ago! The Tein rods came on the car I am not sure when they were fitted. I was planning on getting him to lower the suspension and get him to set it up so hopefully he can highlight what the current camber settings are. Quote Link to comment Share on other sites More sharing options...
GrahameJ Posted March 18, 2018 Share Posted March 18, 2018 6 hours ago, 350Butcher said: Litchfield do only do Ecutek (so 370z's only) Bit of a drive (but a nicer one, make sure you take the B4494 from Chieveley to Wantage on your way home its epic!!) but go and see Jez at Horsham he'll get the best from it for you. Looking at the pic of your car it looks like its running a load of positive camber on the rear (Unless the camera is distorting it) so get yourself a full alignment done while you're there! Also where did you get the Tein rods and ends? Thought they'd been discontinued a while ago! I got a set of tie rods and ends from Driftworks. Their website only shows the tie rod ends at the moment, but no doubt they will be able to get some for you: https://www.driftworks.com/tein-strengthened-tie-rod-ends-nissan-350z-z33-02.html They give a big improvement in steering lock, and although I don't get my car sideways much, they sure make parking in tight spaces a lot easier! Quote Link to comment Share on other sites More sharing options...
350Butcher Posted March 18, 2018 Share Posted March 18, 2018 7 hours ago, Matt V6Z said: The Tein rods came on the car I am not sure when they were fitted. I was planning on getting him to lower the suspension and get him to set it up so hopefully he can highlight what the current camber settings are. Nice mod to come with. If it is out as far as it looks then I'd get under it and with a few simple measurements you'll get it driving far safer till you get it sorted properly. 30 minutes ago, GrahameJ said: I got a set of tie rods and ends from Driftworks. Their website only shows the tie rod ends at the moment, but no doubt they will be able to get some for you: https://www.driftworks.com/tein-strengthened-tie-rod-ends-nissan-350z-z33-02.html They give a big improvement in steering lock, and although I don't get my car sideways much, they sure make parking in tight spaces a lot easier! Think the reason they are "out of stock" is because they've been discontinued. I just like the design of them, look far beefier than stock for taking curbs on track.............and parking in tight spaces too of course! 1 Quote Link to comment Share on other sites More sharing options...
