Auto-dimming mirror?
antnee
I've had my 370 for just 2 weeks but already wishing it had an auto-dipping rear view mirror. My Alfa has one and it makes night time driving much more pleasant.
Has anyone retro-fitted one before?
It looks like you can buy them for other Nissans (eg Nivara) and they have the same screen mount - so would just need connecting up. Is it that simple?
  • 2 months later...
It's a standard connector I picked some up off ebay :) it's an easy mod the navara workshop manual has the pin diagrams you only need three wires (positive, negative and reverse) if you've installed a new head unit then you'll already have those wires no doubt exposed, pop the headliner out slightly and it's all tucked neatly away!
Ok. I have been trawling the net for hours trying to find the connector. Some places in the US have it listed, but it ends up being $40 shipped here! So I have ended up messaging a few eBay sellers that are breaking GTRs and Navaras to see if they can sort out the connector for me.
If it's the linear 7 pin it's a bog standard electrical connector look for jst 7 pin, they're a few quid on ebay etc. Very few connectors in cars are proprietary it's just a pain to find out exactly what they are
I had seen the connectors, but only as a bare housing. However I just found the terminals now too, all coming from a UK supplier for about £6 :) I will update when everything arrives.
My £15 Navara mirror with wiring loom was fitted today and wired to the submarine light in the overhead panel, which switches on/off with the sidelights/headlights.  Nice cheap upgrade on what is otherwise a nicely specified car.
Good stuff! I opted against using the tat light panel as there's lots of nasty stories about what happens when it goes wrong but it's all good!
Care to share those stories? I will be having a go at sorting mine tomorrow, and planning to use the same light as my feed.
Is it just a 350Z issue?
There are some other posts around, I can't recall the specifics but it amounted to if you mess it up you at best need a new dome light and at worst the body control module goes pop. I had to replace the dome light when I shorted it with some duff leds luckily the body control module was fine.
Depends what you fancy doing, your going to need to I clip the headlining anyway and if you've already fitted an aftermarket head unit then you've had the centre console out. I opted to do that and run the reverse wire up so it works as intended but as long as it works anyway you choose is fine!
Edited by MDMetal
A few pictures then;
Connector made up with the cable, inserted into the mirror (how has some heatshrink on too)
IMG_20180528_104246520 by Anthony Molyneux, on Flickr
Mirror mounted, cable routed up and under the rain/light sensor cover
IMG_20180528_114609093 by Anthony Molyneux, on Flickr
And the cables I tapped into (for the ambient lighting LED)
IMG_20180528_115115577 by Anthony Molyneux, on Flickr
And its done!
IMG_20180528_115910772 by Anthony Molyneux, on Flickr
Edited by antnee
On 19/05/2018 at 20:34, MDMetal said:
After reading this thread I too obtained a Navara mirror & fittings (Ebay) and yesterday I fitted it. The only difference is that mine has not got an ON/OFF button. I realised after fitting that the rear of the mirror has its own day/night sensor so although I wired it to the blue & yellow wires any ignition live would have sufficed. But anyway I guess the blue yellow wires are the  easiest to tap into.
  • 4 years later...
Hi were did you take the reverse light supy from?
