Project Garage and other stuff
ATTAK Z
9 minutes ago, Ebized said:
I see you have gravel outside the gravel entrance and I find warm tyres will often pick them up (and even when the car has been standing on gravel for a while) and get carried into the garage.
I presume you have chosen tiles that will be resistant to scratching from stone pick-up, particularly if you have to alter the angle going in/out of the garage?
Ha hah, no, I chose them because they were cheap
31 minutes ago, veeg33 said:
Now I get where "living in a goldfish bowl" comes from :thumbs:
Edited by Ebized
  • Haha 2
Those tiles actually look the same as I put in the family bathroom when I did that 8 years back. Porcelain ones from B&Q if I remember correctly. I used black grout though. Looks very nice, although I thought stuff like trolley jacks etc and all the mechanical work I do in the garage would soon chip/damage them.
Yeah they are porcelain and as I said above they're not really practical for a garage when you intend to work on the car. My skills are in construction rather than mechanical engineering so they're perfect for my needs making the garage easy to keep clean :)
  • Like 2
30 minutes ago, ATTAK Z said:
Yeah they are porcelain and as I said above they're not really practical for a garage when you intend to work on the car. My skills are in construction rather than mechanical engineering so they're perfect for my needs making the garage easy for my cleaner to keep clean :)
Fixed that for you ;)
  • Confused 1
  • 3 weeks later...
On 07/11/2018 at 18:19, ATTAK Z said:
Following on from completion of my garage extension project and in the spirit of Chris's (Keyser) marvellous mechanical engineering threads which I know we are all in awe of ...
... I'm proposing a couple of smaller construction projects for you to follow if you're interested ...
Project A involves the construction of a porch at my back door (oo'errr missus)
The porch project commenced today ... photos to follow
  • 3 weeks later...
  • 2 months later...
So now it's time to get on with the waterfall ... This is where it's going ...
The extent is defined by setting out the edging ...
... and the over-site membrane is installed ...
Look at the clock :)  ...
LUNCHTIME
ATTAK Z - MINIMUM EFFORT :wheelchair: MAXIMUM EFFECT :)
Edited by ATTAK Z
  • Like 2
Back to work - pump is wired up and tested ...
... various positions for the reservoir and furniture are checked out - 3 bags of  6 mm Harvest Buff delivered and installed ...
Note area gets the afternoon sun ... maybe time to relax, survey and plan with a cheeky glass of vino ;)
