Quote to fit front splitter advice.
Lumby101
Moved to a more suitable sub section for you Tia. :thumbs:
If it's £350 to fit and spray then tbh it's what I'd expect some places to charge but definitely on the high side imho. Always best to get several quotes.
Personally I would of thought it should be more like £50-£80 for spraying and maybe another £50-£80 for fitting. Just a guess.
I sanded, primed and sprayed mine gloss black (don't need to clear it if it's gloss) while it was off the car and then fitted it.
Painting part was easy and I got a nice finish on it (just need patience with sand paper!) the fitting wasn't hard but I wasn't happy with just using self tappers & double sided in to the arch liner so I've taken it off until I can tiger seal it and bolt it instead.
This was when it was on;
Also good vid on there to fit yourself.
Hope this helps!
