Dougtosh Posted February 23, 2018 Share Posted February 23, 2018 Hi. Driving on motorway about 65-70 when I felt a loss of power for a second like I had no drive to rear,it picked up again right away but the TC AND ABS LIGHTS came on and stayed on. Pressing TC button didn't put them off. When I stopped I restarted the TC and abs lights stayed on. Also when restarting there was a slight hesitation a bit like starter motor (sounds like TCH TCH TCH) before kicking in. Any ideas please? Thanks Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 23, 2018 Share Posted February 23, 2018 Any codes stored Dougie? What is the condition of the battery? Check battery terminals and starter motor connections. Top up brake fluid right to the top. Report back once above attended to. If you are at Knockhill tomorrow I can have a quick look. Alex. Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted February 23, 2018 Share Posted February 23, 2018 I remember when my brake light switch under the pedal was faulty, the ABS and TCS lights stayed on. If you depress the brake pedal and the brake lights don't work properly, that'd be a clear sign Quote Link to comment Share on other sites More sharing options...
andy james Posted February 23, 2018 Share Posted February 23, 2018 My abs,tc,brake light started staying on. As many have said it could be low brake fluid level,the low fluid level sensor or a faulty abs sensor. Got lucky and sorted it out by replacing the two front abs sensors at £17 each. Lights out. Quote Link to comment Share on other sites More sharing options...
Dougtosh Posted February 23, 2018 Author Share Posted February 23, 2018 Cheers. Nicola used car today and it started and ran no problem, no TC/abs lights on. I'm going to nip up to Knockhill tomorrow, hopefully better weather than last trackday,you done well driving round in that Alex, I'll see you there. Thanks again Dougie Quote Link to comment Share on other sites More sharing options...
