What should I do?
Argyll
due to me being a dozy T**t I've taken of the four bolts holding the caliper together rather than the two bolts holding it on! I didn't realise until some brake fluid started leaking as I loosened the last bolt.
What action should I take? is it just a matter of bleeding that one caliper or should I do more/ Also what brake fluid should I use dot 4 or 5.1.
Thanks in advance for any replies.
Just tighten up the bolts and rebleed the brakes with dot4 :thumbs:
