Doug426 Posted February 1, 2018 Share Posted February 1, 2018 Hi all, A few general issues with the rear suspension on my 350. Car was put in for mot yesterday and failed on a few things (nsf banana arm bush was knackered and rear brake lines corroded) which were sorted out. Seems she’s in a poor state that I want to get right. However whilst having these things sorted a few other issues cropped up. list of issues. Ns rear shock weeping and needs replacing, no idea how it was missed on the mot. wheel alignment is out on all four wheels, however they (being the local tyre fitters) couldn’t loosen the rear camber or toe bolts (even with a lot of heat) to adjust without risking putting it off the road, so have left for now. my questions are these, 1. Looking for reasonably priced Oem standard shocks to replace, have no real need of uprated shocks, after looking around (and getting quoted stupid prices from dealer) I’ve not really come up with anything, are there any oem part sellers that can provide the shocks? 2. I need to get new rear toe and camber bolts before the 4 wheel alignment can be done, everywhere I look it comes up with the spc bolt kits but this requires “adjustments” to the mountings, is this really the best option when not planning to modify? thanks in advance for any help. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 1, 2018 Share Posted February 1, 2018 All parts are in stock to fix your issues and good to go same/next day Just drop me a PM if I can help further. Alex. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted February 1, 2018 Share Posted February 1, 2018 Hi Doug, If you're looking for new OEM like shock see here: https://www.torqen.uk/nissan/350z/suspension-steering/springs-shocks/811-350z-kyb-excel-g-shocks-full-set-341366341367344455.html Bolts options: https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/873-350z-spc-rear-toe-bolt-kit-72055.html or https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/762-350z-eibach-pro-alignment-rear-camber-and-toe-bolt-kit-572055k.html or https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/12517-350z-moog-rear-adjustable-alignment-cambertoe-kit-k100172.html Let me know if you need further information. Quote Link to comment Share on other sites More sharing options...
