EML & P1147
mr v6
Setting off from the lights today & the EML came on. Car was fully upto temperature. Read it with the ELM327 with the above code, cleared it & carried on. It hasn't come back on yet. I've read a number of topics on here that suggest replacing the sensor. I'm firstly going to check the connector & wiring to check all that is ok, then make sure I've got no vac leaks after the MAF. I don't I do have as no work has been done sonce an oil change in October.
I'm right in saying, correct me if I'm wrong, it's the drivers side, after the car, the one that clips to the underside of the gearbox? Blue connector I think?
ThanksB)
