tspar Posted January 16, 2018 Share Posted January 16, 2018 Have scanned the owners manual and cant find them mentioned. Can they be turned of at all as I find them the most irritating thing on the planet ! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 16, 2018 Share Posted January 16, 2018 Why not just disconnect them? Quote Link to comment Share on other sites More sharing options...
tspar Posted January 16, 2018 Author Share Posted January 16, 2018 5 minutes ago, ZMANALEX said: Why not just disconnect them? May just have to if no other option. If you (or anyone) have an info on which fuse to remove that would be great. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 16, 2018 Share Posted January 16, 2018 Not sure if there is a dedicated fuse, save time searching and just disconnect. Quote Link to comment Share on other sites More sharing options...
tspar Posted January 16, 2018 Author Share Posted January 16, 2018 1 minute ago, ZMANALEX said: Not sure if there is a dedicated fuse, save time searching and just disconnect. Thanks for the info mate. Unfortunately i have to admit to my complete ignorance when it comes to car electrics so would not know where to start disconnecting them? Quote Link to comment Share on other sites More sharing options...
SHEZZA Posted January 16, 2018 Share Posted January 16, 2018 (edited) The control module will be in the boot in the near left corner behind the plastics just un plug it from there as I think it picks a local feed up from the reverse lamp. If you remove the centre section of plastic with the vanity light unit you should be able to get your arm in from there. The module is on Velcro so should just pull of and out. That’s what I did when mine just constantly beeped due to a faulty sensor. Edited January 16, 2018 by SHEZZA Quote Link to comment Share on other sites More sharing options...
tspar Posted January 16, 2018 Author Share Posted January 16, 2018 5 minutes ago, SHEZZA said: The control module will be in the boot in the near left corner behind the plastics just un plug it from there as I think it picks a local feed up from the reverse lamp. If you remove the centre section of plastic with the vanity light unit you should be able to get your arm in from there. The module is on Velcro so should just pull of and out. That’s what I did when mine just constantly beeped due to a faulty sensor. Cheers mate. Will give it a go Quote Link to comment Share on other sites More sharing options...
